No heat on drivers side
Old Dec 8, 2015 | 07:28 PM
Donnbuk1's Avatar
Donnbuk1
Default No heat on drivers side
Just bought a 2nd gen GS300 but when I turn the temperature up, the drivers side still blows cold. Also the air is not blowing high either. Not sure if it's servo problem.
Old Dec 8, 2015 | 07:50 PM
GSTim's Avatar
GSTim
Sounds a lot like the servo.
Old Dec 9, 2015 | 06:02 AM
Gunnut's Avatar
Gunnut
Same thing happened to me and I thought it was the servos as well since I've been hearing the 'mouse scratching noise for some time. I bought the servos but never installed them. Turns out I was really low on coolant. Weird thing is the radiator always showed full. Eventually I parked the car facing up an incline and checked the radiator when the engine was cold. It was empty so I filled it along with the reservoir. Had to do this a few times until it filled completely.
Problem went away. I still need to replace the servos because the scratching noise is annoying.
This all happened about 2 years ago.
Old Dec 9, 2015 | 08:17 AM
Mcon's Avatar
Mcon
I send a few thread that you need to check. This is one of them;
https://www.clublexus.com/forums/gs-...iver-side.html
Old Dec 9, 2015 | 08:29 AM
Mcon's Avatar
Mcon
Another thread;
https://www.clublexus.com/forums/gs-...rt-number.html
Old Dec 9, 2015 | 01:57 PM
brainsurge's Avatar
brainsurge
Recently my gs430 also did only blow cold air, except on the highway temperature got up to normal. turned out to be the thermostat, had a broken rubber seal.
jasepb
Apr 11, 2019 03:07 PM
shumif1
RX - 1st Gen (1999-2003)
Jun 9, 2013 01:13 PM
- V -
Aug 7, 2012 10:57 PM
COOLIS
IS - 1st Gen (2001-2005)
Jan 8, 2009 12:00 AM
