Single popping noise everytime I hit the brakes
Old 09-02-15, 05:38 PM
Lukas99GS
Lukas99GS's Avatar
Default Single popping noise everytime I hit the brakes
Like the title says whenever I hit my brakes going more than 20-30 mph the second I tap the brakes I hear a metal popping sound from what seems like the front right of the car, I recently had that caliper replaced as well as inner tie rods and it seemed to start soon after that, but it makes the sound whether I lightly tap the brake or brake hard.
Old 09-02-15, 06:29 PM
RXGS
RXGS's Avatar
I'd assume its the clips and springs that have tension on the brake pad. Im replacing those on my car while i replace the upper control arm (for the third time).
Old 09-02-15, 07:47 PM
TTurboPimp
TTurboPimp's Avatar
check to make sure the caliper is torqued down correctly
Old 09-02-15, 08:23 PM
wbmx1981
wbmx1981's Avatar
Caliper bracket might not be torqued down enough. It should be 87 ft lbs. I had the same clunk, torqued them down correctly and the issue went away for good.
Old 09-03-15, 02:21 PM
Sevenevez
Sevenevez's Avatar
do you have coilovers? mine used to make that noise only when slowing down to a stop
Old 09-03-15, 04:40 PM
Toysled
Toysled's Avatar
I'd say take a look at the caster arm (#2 lower control arm).
48068E
Check the bushing on part 48068E. Hope this of help!!
Old 09-05-15, 02:11 AM
kit cat
kit cat's Avatar
Jack car up, wiggle the crap out of all the arms.
Could be the lower control arm #2 bushing as mentioned above... I'd also check the end links (especially if your car is lowered).
DanKennedy
GX - 1st Gen (2004-2009)
12-18-18 03:20 PM
Baptizer
09-03-14 12:21 PM
ls400beave
09-17-12 05:12 AM
linhqt
08-24-11 12:33 PM
Jimbo2828
Suspension and Brakes
04-14-05 07:29 AM
Quick Reply: Single popping noise everytime I hit the brakes
