GS Overheated HELP!!!!
Old Jun 29, 2015 | 05:51 AM
  #31
STREETGS's Avatar
STREETGS
it turns out these o rings can only be found through the dealer,
i was told almost all lexus dealers stock these o rings because they ar common to leak.
as he diagram above showed there are 3 o rings.
Old Jun 29, 2015 | 06:09 AM
  #32
STREETGS's Avatar
STREETGS
Applied a small amout of oil on the o rings
All back together
Used a steel wool to clean it up
Removed the pipe, to replace the inner o ring<br/>
Removed the pipe
Old Jun 29, 2015 | 06:11 AM
  #33
STREETGS's Avatar
STREETGS
Sorry the pix didn't quite upload in order.
Old Jun 29, 2015 | 09:32 AM
  #34
shwalker07's Avatar
shwalker07
Looking good.
Old Jun 29, 2015 | 03:20 PM
  #35
Mcon's Avatar
Mcon
Thanks for the update.
Old Jun 30, 2015 | 06:36 AM
  #36
STREETGS's Avatar
STREETGS
remember this is known to leak at some point on all gs 2nd gens
its a very very small leak check your car once in a while for any coolant residue around the area,
you might not even see any coolant drip on the ground since its small it might evaporate as it makes its way down.
(this was my case)
Old Jun 30, 2015 | 07:19 PM
  #37
lextout's Avatar
lextout
Good thread and very informative!
360jdm
Apr 12, 2019 06:57 PM
pubbin
IS - 1st Gen (2001-2005)
Oct 30, 2016 02:34 PM
lionscourt
Oct 21, 2015 08:00 PM
Daihuy
Apr 15, 2007 09:39 AM
actuary
Jul 21, 2005 04:22 AM
