1999 GS300 ABS module bad
Old Jun 11, 2015 | 07:38 PM
ViciousSoa's Avatar
ViciousSoa
Default 1999 GS300 ABS module bad
I just bought a 99 GS300 with a hard brake pedal and beeeeeeeeeeeeeeeping noise. Brake light is on but the other 2 VTC and I never see they on (maybe previous owner disabled).
I been research forever for a fix solution with out spending $2200 for a new one or gamble with another old one like $400-$500.
so I pull the 2 wires that go to the beep speaker right on top of the brake pedal. That **** give me headache . DISABLED that.
I took ABS unit out the car 4 screws from inside and pull the pin. I pulled all the plug and the unit wiggle wiggle it out.
lose 2 wires from the module to the motor and applied 12V direct from the battery, NOTHING happened. No turning, no noise. So... I lose 2 allen screws that motor mounted on and the other 2 allen screws from the adapter plate (between the motor and the .... fixture). Bend the plate behind the motor and then took the motor apart.
First thing I noticed is the 2 pieces of the collectors are missing ... or ... dusted...
I hope this is the common issue that everyone and I frustrated about.
Now I need help to find the collector piece, where to buy/order. I took few measurements so yall can help me or yourself.
Check out the pics.
2 of the collectors are gone.
~0.84in diameter of the collectors
~0.875 upper bearing
~0.59 in bottom bearing
Old Jun 11, 2015 | 08:38 PM
ViciousSoa's Avatar
ViciousSoa
more researches came up with Mitsubishi Pajero 2000-2003 with ABS, they are looks alike. May be Toyota and Mitsubishi favor Aisin products back then.
Old Jun 12, 2015 | 04:27 AM
Mcon's Avatar
Mcon
I know is a company that only sell it those bearings, but I can remember the name of that company. Try to google it with the measures that are you took. You can also try MSC Industrial Supply.
Old Jun 14, 2015 | 08:20 PM
ViciousSoa's Avatar
ViciousSoa
Default no luck
I went to that website and couldnt find what I need. The piece I need is called "commutator".
The spec of that piece is 12p (12 tabs)
23mm outer diameter
9mm inner diameter
12mm is the length or height.
Old Jun 15, 2015 | 02:25 PM
SC4Paulo's Avatar
SC4Paulo
When I stopped by Lexus the other day I was able to look at the whole ABS diagram. They sell it in pieces too. not just the whole piece. I saw part numbers and everything.
Old Jun 17, 2015 | 11:03 AM
ViciousSoa's Avatar
ViciousSoa
are you sure ??? which Lexus ?? I want to call them and order it
Old Jul 28, 2023 | 06:37 AM
Jumba's Avatar
Jumba
4th Gear
hey any luck finding the correct commutator
Old Aug 10, 2023 | 08:30 PM
Jumba's Avatar
Jumba
4th Gear
for those going through the same issue
here
Amazon Amazon
speedkar9
Mar 15, 2017 07:54 PM
AlbertG
Jun 30, 2014 06:04 AM
Goblejosh
Apr 7, 2014 03:53 PM
asko36
Suspension and Brakes
Mar 9, 2013 11:14 AM
simontibb
GS - 1st Gen (1993-1997)
Jan 17, 2008 02:09 PM
