Slipping when accelerating
Old Apr 29, 2015 | 12:05 PM
Garz's Avatar
Garz
Default Slipping when accelerating
I notice a slight slip when accelerating hard from a dead stop. Possibly drive line or rear end related. Has anyone else experienced this? There's nothing in the trunk sliding around.
Old Apr 29, 2015 | 12:57 PM
2GSKaizen's Avatar
2GSKaizen
Sure it's not transmission related? Does it feel like it's in neutral for a split second?
Old Apr 29, 2015 | 01:56 PM
Garz's Avatar
Garz
It does feel like it's in neutral for a second. Then it grabs and goes. It won't do it unless I'm hammering it. It might be tranny related. IDK. I'm just gonna drive it until it isn't worth fixing anymore.
Thanks.
Old Apr 29, 2015 | 04:29 PM
marshun's Avatar
marshun
does your traction control light flash?
Old May 1, 2015 | 03:12 PM
Garz's Avatar
Garz
Traction control light doesn't flash. It might have something to do with my front wheel sensor being broke/not working when my lower ball joint failed. The VSC light is on because of this. Hmmm.
Old May 1, 2015 | 04:31 PM
bonesnj0's Avatar
bonesnj0
Try Lucas trans fluid, Don't beat on it and it may last a while.
Old May 2, 2015 | 08:52 PM
RamAirRckt's Avatar
RamAirRckt
Check trans mount and rubber driveshaft "joints"
Mine does same. Trans is fine, best to leave it alone. I am betting my trans mount is getting tired. If you take off gentle, fine, if you take off "normal" or slightly aggressive, it feels like the wheel spins a half to one turn or so before you take off right?
Old May 3, 2015 | 12:48 AM
Category5's Avatar
Category5
Yea I'd check Trans mounts, and shafts joints along with all the bushings. I def. wouldn't put Lucas Trans fluid in my Trans that's for sure, you may want to reset the cpu as well it could be also doing that because it's been accustomed to slow take offs. Reset it and drive it hard for a bit, see if it clears up at all. Also obviously check your OCV clean that thing out.
Old May 4, 2015 | 04:46 PM
Garz's Avatar
Garz
Just ordered a westar tranny mount. Let's start there. It is idling a bit rough too.
Thanks Gents.
Old May 4, 2015 | 06:29 PM
marshun's Avatar
marshun
feels like a rough idle? motor mounts probably too.
Old May 5, 2015 | 10:35 AM
Garz's Avatar
Garz
Yep, same here. Hopefully someone totals the car for me; which wouldn't take much. It's probably worth $5500. But it's still a nice driving car that's 15 years old.
Old May 5, 2015 | 12:18 PM
RamAirRckt's Avatar
RamAirRckt
Trans mounts are likely shot by 200k (mine 237k and I think mine is getting loose). All depends on the driver. If they are nailing the gas heavily daily, much sooner, if they drive very gentle, very long.
Mine has a small slip feeling on take off if get on it just a little. I will get to it this summer. But I know that it isn't trans friction related. It has to be driveline (bushings) somewhere. I injured the bursa on my kneecap so I can't get down on my knees for a while so it will wait, it has all winter....
Have someone stare at each tire when you accelerate and watch it. See what is going on, wheelspin or ?
Try this, Foot brake hard and give it throttle, feel if you feel it. If trans slipping it will probably get worse, if mount you will feel almost same feeling as you do when you are driving. It will "slip" and just load up on the brakes. Don't hold it long, the heat build up is incredible. So do it only as needed.
Old May 5, 2015 | 02:17 PM
KeyKeeper's Avatar
KeyKeeper
Or possibly the delay due to fly by wire throttle?
Old May 5, 2015 | 02:18 PM
RamAirRckt's Avatar
RamAirRckt
Could be, mine, no, mine's a GS400. But the GS430's could potentially have more of an issue. My wife's 04 RX330 DBW is fine, no issues for the most part until you nail it hard when you NEED it and it isn't there....
Jmo882
RX - 1st Gen (1999-2003)
Jan 4, 2019 04:18 PM
BSC300TT
Jun 22, 2010 08:36 AM
Grimm333
Apr 22, 2005 05:37 PM
DroppedGS
GS - 1st Gen (1993-1997)
Jun 27, 2004 11:13 PM
supercoupes
Sep 2, 2002 06:52 PM
