city light removal help please..
Old 08-07-14, 09:45 PM
itztwinki3
itztwinki3's Avatar
Default city light removal help please..
I am trying to figure out how to remove the wedge bulb that is in the same housing as the high beam bulb. bought some new led bulbs but cant figure out how to remove them
Old 08-07-14, 09:56 PM
Lutkis
Lutkis's Avatar
The hard way: remove your front bumper and then remove your headlights.
The "easy" way: just twist the bulb cover counter-clockwise and pull it out.
This could be a PIA especially if you have long LED bulbs but it can be done. I've had to do it twice so far.
Old 08-08-14, 06:17 AM
boostedsi
boostedsi's Avatar
yea i have done the change from regular 194 wedge bulbs to longer 6 led bulbs, you can do it without removing the bumper the drivers side is a PIA, but just get someone with small hands to reach in and unlock them (i believe by pushing down) and wiggle it out, and reverse to put them in, i changed mine a few times but it stil sucks, the passenger side should be easy because there is nothing really blocking it.
good luck and remember be gentle on the drivers side cause the leds aren't that strong
Old 08-08-14, 06:24 AM
Mrmartin
Mrmartin's Avatar
No excuses, I've got big monkey hands and I installed 13 SMD bulbs in mine with minimal bleeding.
Old 08-08-14, 05:05 PM
itztwinki3
itztwinki3's Avatar
thanks guys got it done earlier today. passenger side took me 2 minutes literately. on the other hand the driver had so much room it took me 30 minutes to do lol
Old 08-09-14, 04:23 AM
DOPEPICS
DOPEPICS's Avatar
very easy to do....
Old 08-09-14, 07:11 AM
MikeFoxx
MikeFoxx's Avatar
if you cant get your hands in there or dont have anyone around who can... you can actually remove the headlights without taking the whole bumper off. I've done it several times when I setup my LS430 retrofit. Takes about 10 minutes to remove the headlight.
Anyone looking here in the future the link is in the Sticky but I'll let you find it.
Old 08-09-14, 11:11 AM
itztwinki3
itztwinki3's Avatar
care to explain how you did that without removing the bumper?
Old 08-09-14, 06:16 PM
MikeFoxx
MikeFoxx's Avatar
Sticky: ★ 2GS FAQ (Frequently Asked Questions) and DIY Thread ★ FAQ & DIY
there are two separate threads on it.
Old 08-10-14, 10:42 PM
Lutkis
Lutkis's Avatar
I'd think it's easier to just try and get the bulb there without removing the headlight.
FYI it is impossible to take off the headlights without removing the front bumper on Euro models.
But yeah, I guess this is about US models.
Old 08-11-14, 08:22 AM
MikeFoxx
MikeFoxx's Avatar
Touche Lutkis you are correct... I forgot about that when we discussed it during your retrofit. I had the same issue as OP because my LEDs where really long so I just waited till i was taking the headlight off to pop them in.
Anyone taking the headlights off without removing the whole bumper... you should tape off around the outter low beam section of the fender/bumper. There is a plastic prong that slides into the outer most part inside the fender and this is the only piece that could possibly cause any damage if you aren't paying attention.
2006GeeEss
03-15-18 01:34 PM
Propulsion
10-07-17 11:38 AM
oardila99
GX - 1st Gen (2004-2009)
05-22-13 09:40 AM
seattlegs
11-06-09 03:03 PM
Stealther
Lighting
04-08-03 12:15 PM
Quick Reply: city light removal help please..
