DIY help with o2 sensor!!!
Old May 8, 2014 | 07:15 AM
2jKarma's Avatar
2jKarma
Default DIY help with o2 sensor!!!
I have 2001 gs3 and I threw a cel its my o2 sensor, bank 2 sensor 1 I need help on how to remove it o2 socket and crowfoot tool does not seem to work what so ever and im at a stand stil does anyone know how to remove it?!?!?!
Old May 8, 2014 | 07:22 AM
bagwell's Avatar
bagwell
might get more help here
Old May 8, 2014 | 07:28 AM
GoFastTSI's Avatar
GoFastTSI
Apply liberally with liquid wrench, allow to penetrate overnight, get big on it with a breaker bar and O2 socket. Easy.
Old May 8, 2014 | 10:31 AM
2jKarma's Avatar
2jKarma
Thanks ill spray it down when I get home hope it works!
Old May 8, 2014 | 12:03 PM
4TehNguyen's Avatar
4TehNguyen
they make special tools to take out O2 sensors if its a recessed one
Amazon.com: Powerbuilt 648691 Oxygen Sensor Offset Puller: Automotive Amazon.com: Powerbuilt 648691 Oxygen Sensor Offset Puller: Automotive
Old May 8, 2014 | 02:54 PM
2jKarma's Avatar
2jKarma
Originally Posted by 4TehNguyen
Recessed how so???
Old May 8, 2014 | 06:27 PM
MrG4Life's Avatar
MrG4Life
CL Folding 100,000
Good luck getting them loose OP. I tried changing the sensors for Bank 2 and got really frustrated and eventually gave up. I saturated the sensor with PB Blaster and still could not get it to break loose. I was trying to get my hands on a blowtorch to help loosen them but couldn't get one. I just don't have the spare time now so I'm letting my mechanic change them for me. This is how my o2 sensor removal tool looks like:
Old May 8, 2014 | 06:48 PM
2jKarma's Avatar
2jKarma
Yeah I know exactly what u mean Im surprised I still have a car I was so mad I couldn't get the o2 sensor out I had to walk away from it and I have both tools you posted up but I never tried the breaker bar I wonder if would work?
Old May 9, 2014 | 08:26 PM
sung35's Avatar
sung35
Let the car run until hot then stop the engine. Let it cool down a little until the heat is manageable. The heat will soften the metal. Trust me, i could not get any of it out at all until i tried this method. You will have to feal with the heat under the car, but it will come loose much much easier. Good luck
Old May 9, 2014 | 11:10 PM
DosyBoy's Avatar
DosyBoy
Why do Gs3' constantly have problems with O2 sensors?
Old May 10, 2014 | 06:20 AM
runyun's Avatar
runyun
The above wont work. There's not enough space between the socket and firewall to get that on.
I did my friends Bank 2 Sensor 1 in March, we used this tool from autozone (along with the pipe from my jack as a breaker bar) We did use some PB blaster as well.
http://www.autozone.com/autozone/acc...er=948079_0_0_
They are corroded on, so make sure whatever tool you're using is sitting flush. If not, you're just asking to strip it
Old May 10, 2014 | 01:10 PM
PHML's Avatar
PHML
Master Thread Closer!!
That's what I do....and open ended wrench does the trick.
Lexmex
RX - 1st Gen (1999-2003)
184
Sep 18, 2025 02:50 PM
C6r
Feb 8, 2020 08:39 PM
jmsmiff
Mar 27, 2013 07:28 PM
KTGS300
Maintenance
Jul 20, 2007 04:39 PM
carcass66
May 30, 2004 01:28 PM
