Weird Headlight problem
Old Apr 2, 2014 | 07:50 PM
Rhoov1's Avatar
Rhoov1
Default Weird Headlight problem
Hi all,
New to the forum, have a 98 GS400 with 234,XXX mi. Passenger side headlight turned pink a couple days ago. Did some research and found that the bulb was starting to go out. Went to autozone and grabbed a new Sylvania HID D2R... came home and installed it and had no light. Reinstalled the factory one and it light up pink, so i assume I have a bad bulb and return it to autozone in exchange for a new one. Installed the new one and it immediately lit up bright white. walked away from the car for about 10 minutes and went to leave, turned on the headlights and the passenger side did not come on. When you get real close you can see the light acting like it wants to come on and there is a static buzzing noise for a second or two then nothing. From what it looks like to me it is a ballast problem, am I correct in assuming that or am I totally off base? Sorry if this has been covered before but could not find my problem while searching. Never had to deal with HID before so not exactly sure, any help would be appreciated!
Thanks in advance.
Robby
Old Apr 2, 2014 | 09:58 PM
DosyBoy's Avatar
DosyBoy
Yes your ballast is shot...check a junkyard for a used one
drgrant
Jun 17, 2019 07:04 PM
exiakira
Nov 3, 2012 01:04 AM
jbrooksga
Mar 29, 2011 11:53 AM
TPSTulane
Jan 30, 2009 09:42 PM
stefnee
Oct 25, 2007 01:47 PM
