negative experience? crc maf cleaner
Old Mar 21, 2014 | 01:10 AM
PHML's Avatar
PHML
Master Thread Closer!!
Never had a problem with CRC MAF cleaner.
Also clean throttle body with CRC throttle body cleaner.
Are you using an aftermarket air filter/air filter system? K&N or similar type that requires oiling of the filter? If so, don't spray too much oil...that's how the MAF and throttle body gets gunk on there.
Also use ethanol-free gas and put fuel injection cleaner in your tank....hope that helps.
If that still doesn't fix the problem...scan for code...maybe its your spark plugs or coil packs.
Good luck.
Pete
Old Mar 21, 2014 | 10:25 AM
PearlESC3's Avatar
PearlESC3
Used CRC maf cleaner and also CRC TB cleaner this last week on my 98 GS400, worked great with no issues. Cleaned up those dirty little sensor wires on my maf nicely. Just make sure to let it dry completely.
Old Aug 30, 2014 | 02:20 PM
LSBen's Avatar
LSBen
I used it on my 01 LS430 with no problems. It doesn't have the Vortex MAF.
Old Oct 15, 2014 | 07:26 AM
Alphaman19's Avatar
Alphaman19
I took my maf sensor unit out last night and sprayed it with CRC maf cleaner. I basically just shot a few bursts of the cleaner into the bottom end of the unit.
Question: does the unit come apart/be disassembled for better cleaning? I though I heard some folks mention a screen or something inside that could be dirty also.
It looks like a thick black plastic card with a large plastic bullet on the end (sorry for the poor description).
The two screws that go into it gave me the impression that it could be taken apart; though I didn't force the issue.
thanks in advance.
98 GS4
Old Oct 15, 2014 | 09:49 AM
MikeFoxx's Avatar
MikeFoxx
DO NOT try taking it apart... just remove it from the car... spray it let it dry.
I've used this product now on a 1992 SC400, 1998 GS300, 2007 IS350 without a single issue at all.
Old Oct 19, 2014 | 09:17 PM
kit cat's Avatar
kit cat
Read the detail on the bottle. You should not use the CRC MAF cleaner on a Harman whatever type MAF sensor on a GS300.
Old Oct 20, 2014 | 11:05 AM
RamAirRckt's Avatar
RamAirRckt
I have used with no issues, I use very rarely, I would rather brush it with a cloth given the choice. but I also know my MAF's....
Old Oct 20, 2014 | 03:04 PM
GS4_Fiend's Avatar
GS4_Fiend
Totally safe with ALL HOT Wire type MAF sensors. If you see 2 resistors, those are the ones that you spray on.
Old Oct 20, 2014 | 07:08 PM
kit cat's Avatar
kit cat
Read the fine detail...
Originally Posted by Poqman
I need help from the experts. I have a 2002 SC430 with 91k miles that is starting to run a little rough at idle. I read the threads that say cleaning the MAF sensor and throttle body helps smooth out the idle so I went to the auto store and bought CRC MAF Sensor cleaner and CRC throttle body cleaner. When I got home and read the can, the MAF cleaner says "DO NOT use on vehicles with a Karman-Vortex air flow sensor, e.g. Toyota Supra Turbos, Mitsubishi's and most Lexus vehicles." Can anyone tell me if the SC430 uses a Karman-Vortex air flow sensor? The sensor on the car has a Toyota Denso part number. If it is a Karman-Vortex, what brand of MAF cleaner is okay to use with our cars? Thanks!
https://www.clublexus.com/forums/sc-...on-vortex.html
Old Oct 20, 2014 | 09:05 PM
MikeFoxx's Avatar
MikeFoxx
Has anyone met the leprechaun who has ever had an issue with this on our MAFs? I have yet to see their post... yes the label states do not use it but we have yet to meet the person who has issues with using this cleaner. I've seen some with issues for installing without letting g it dry and others who damaged the wires by poking them with the straw... but please someone e for the life of this thread and all other CRC threads please link the failed cleaning so we can end this age old debate lol.
turtlepeas
Aug 24, 2017 04:39 PM
MattJO
GX - 1st Gen (2003-2009)
Apr 4, 2017 11:18 AM
gstreee
Mar 6, 2014 04:56 PM
jtelesio
Nov 28, 2010 06:08 AM
Allaretake
Jun 3, 2010 02:36 PM
