In need of help codes: 0256, 1241, 1251, 1252, 1256, 1223
Old 01-30-14, 07:17 PM
vi37steven
vi37steven's Avatar
Default In need of help codes: 0256, 1241, 1251, 1252, 1256, 1223
Couple of days ago I turned my car on. 99 gs300. the car started making this annoying sound and it wont turn off , also the ebrake, abs, and vsc lights came on. The brake was not working properly. i had to put force on the brake to stop it. So I took it to the shop, they scanned it and these came on C0256 - SRL circuit open, C1241 -low battery or very high battery, C1251- pump motor locked, C1252 - hydro boost pump motor fault, C1256- accumulator pressure low, C1233- something sensor circuit open/ shotrt, and C1223- ABS system fault. The shop said they dont really know whats wrong with it, telling me to bring it to the dealership and I did. On the way there all the lights turned off and the brake were working again. So I thought it was just a short some where then after a couple of days it happened again. Then it went off again and on, now its just the lights that stay on and the brake isnt working properly. So I was wondering what I should check out to see whats wrong with it?
Old 01-17-15, 01:19 AM
StanTycoon
StanTycoon's Avatar
im having the same problem, i think its a battery issue thats causing all those codes, code c1241 is low positive battery, my battery was hooked up wrong, both positive terminals were connected as one
Corey513
01-23-20 06:24 AM
vi37steven
02-08-14 07:42 PM
Jace_91
05-14-09 03:13 PM
Agent$mith
Maintenance
01-16-05 07:37 PM
Quick Reply: In need of help codes: 0256, 1241, 1251, 1252, 1256, 1223
