Pumping guards
Old Dec 20, 2013 | 03:08 AM
Champers's Avatar
Champers
Default Pumping guards
Hi all.
Would it be possible on a 2nd Gen GS to pump the rear guards 2cm and the front guards 1cm without needing to cut into the metal and damage the paint?
Cheers.
Old Dec 22, 2013 | 03:55 PM
Grangerr's Avatar
Grangerr
On both front and rear lips of a GS2 they retain a small square plastic clip which keeps a thin metal trim captive. If you're trying to push your guards out with a roller (after removing the clip) they will tend to buckle oddly and not be a super straight roll. Most guys cut the inner lip off or trim it significantly. I got mine rolled (no cutting) and I reckon they sit about 10mm further out than stock, but on close inspection, they definitely are not straight.
Jwconeil
IS F (2008-2014)
Oct 7, 2018 02:40 AM
FUZCO
Oct 15, 2017 12:09 PM
Bankswood
Dec 17, 2015 09:54 AM
RedPhoenix
Jan 22, 2008 09:34 PM
ArmyJoe
Feb 10, 2007 02:46 PM
