keyless entry problem
Old Nov 15, 2013 | 10:36 PM
1up's Avatar
1up
Default keyless entry problem
I just picked up a 99 gs400. The fob is a Lexus 3 button one. When I press to lock the doors, the car just beeps 4 times and nothing happens. Any clue whats wrong?
Old Nov 16, 2013 | 09:06 AM
Mr Jokster's Avatar
Mr Jokster
First off, welcome to Club Lexus
How do your doors lock with the lock button on your driver door, can you lock them all with no problem? Also, can you lock them all by hand with no problem? Possibility that an actuator is going out and the car is attempting to lock or unlock a second time. Other possibility is that the cable has gotten loose from one of the locks (most likely the driver side) and not allowing the door to initially lock the first time. I have that problem because the plastic ends of the cable on mine is broken and I have to do a little trick to get the door to lock properly. When I dont do it, the car will beep 4 times (2 attempts) and usually opens after that second attempt. Theres a lot more to the issue, but too much to type. Too bad you dont live near by and we could figure it out
Old Nov 16, 2013 | 09:08 AM
Mr Jokster's Avatar
Mr Jokster
Also, you may want to try and reprogram it and see if its just the remote. Do some searching on your problem, there are plenty of thread about this on here as well s reprogramming instructions.
Old Nov 16, 2013 | 06:25 PM
1up's Avatar
1up
I noticed the back driver door won't lock from pressing the door lock buttons or from turning the key in the driver door. All 3 other doors work fine. So you think that could be the problem? Bad back door actuator or broken cable?
Thanks for the reply.
Old Nov 16, 2013 | 08:11 PM
Mr Jokster's Avatar
Mr Jokster
Its not the cable that breaks, its the plastic housing that mounts to the door that breaks. Theres a thread on that here.
jdm93400
Nov 18, 2017 12:42 PM
Joeyc850
Mar 14, 2015 07:51 AM
Aristo722
Feb 16, 2014 09:44 AM
a#'z
Mar 2, 2009 09:25 PM
palaka
RX - 1st Gen (1999-2003)
Sep 24, 2008 11:55 PM
