Pressure Wash OPPPS
Old Mar 30, 2013 | 12:59 PM
w9kcj's Avatar
w9kcj
Default Pressure Wash OPPPS
So dumb *** here decided to pressure wash the GS300 (engine) today Now have check engine light (PO303) ,VSC light is on VSC off light is on . I took apart every connector I cound to look for water and found none.Really didn't hit it that hard with the water! Runs like **** !
HELP !!
Old Mar 30, 2013 | 01:04 PM
Mr Jokster's Avatar
Mr Jokster
I'm assuming you sprayed the engine? Just let it dry and see what happens. Maybe even disconnect the battery to reset. Its probably nothing, dumb ***
Old Mar 30, 2013 | 01:09 PM
w9kcj's Avatar
w9kcj
Jokster,
Thanks for the reply
I tryed getting it warm no help ,took the battery cables off toched them togeather but lights came back on. Don't really want to drive it now as not to puke a converter----
Old Mar 30, 2013 | 01:16 PM
Mr Jokster's Avatar
Mr Jokster
Its just a guess that the vsc lights are only only because its part of "limp mode" due to the misfire. I'd focus on the misfire. Check and see if somehow water got into the air/fuel system. check around injectors, check in the air box and the spark plugs. The only places i can think of that water could get in.
Old Mar 30, 2013 | 01:18 PM
Mr Jokster's Avatar
Mr Jokster
Dont know why you touched the cables together, good way to fry something with the charge stored ANYwhere in the car. Did you keep them off for a good 15-30 mins? (I think it usually takes like 5 to reset, the more the better)
Old Mar 30, 2013 | 01:42 PM
w9kcj's Avatar
w9kcj
I will take them off and let it sit for a while, I took the covers off the top end to check plugs etc. but all is dry there.... Like I said I just gave it a quick spray... OK on limp mode that is what I suspected..
Thanks again
Norm
Old Mar 30, 2013 | 01:45 PM
1sWt2GS's Avatar
1sWt2GS
Lol in the future use simple green it's an easy way to clean the engine bay
Old Mar 30, 2013 | 02:18 PM
Mr Jokster's Avatar
Mr Jokster
Just for fun, check your ABS computer up on the top driver side corner by the windshield. Small possibility that a little water got in those plugs, however if that were the case, I think you'd get that buzzing from there. Doesnt hurt to check though.
Old Mar 30, 2013 | 02:41 PM
lexo98's Avatar
lexo98
Just let it dry out. Leave the battery disconnected for a while. You should be fine.
Old Mar 30, 2013 | 02:45 PM
w9kcj's Avatar
w9kcj
Checked the ABS and every plug I could get apart & left the cables off long enough to have to reset the seats . Still missfireing badly. Guess I'll let it set overnight & hope for better things in the AM. Looks like the motorcycle may be a option for Mon.AM commute but Burrrrrrrr
Old Mar 30, 2013 | 07:43 PM
w9kcj's Avatar
w9kcj
Lexo98,
I hope so ,I really went over everything again tonight.I'll leave the battery cables off and hope for the best on Easter morning. Meanwhile I'm charging the motorcycle battery. Low 30s Mon Am on a motorcycle will be a eye opener !
Thanks again for the help & will keep you posted
Norm
Old Mar 30, 2013 | 08:02 PM
porn-adkt's Avatar
porn-adkt
did the muffler bearing get wet? that may be it
Old Mar 30, 2013 | 08:05 PM
fpayqafa's Avatar
fpayqafa
Old Mar 30, 2013 | 10:10 PM
1UGLYGS's Avatar
1UGLYGS
If you were to even read any part of this thread, the OP already tried that...
Old Mar 31, 2013 | 11:35 PM
sLOWaristo's Avatar
sLOWaristo
Made me lol
