Trunk Lock
Old Feb 20, 2013 | 04:06 PM
ivnnln's Avatar
ivnnln
Default Trunk Lock
Hello All,
I had been having issue with the trunk lock actuator. I can open the trunk with remote only all the doors lock have not opened first. If I press on the remote to open the door first, then the trunk lock won't open by pressing the remote, I have to manually open it by turning the key. That is very weird. I then replaced the trunk lock actuator from the junkyard with the same model GS400 and it worked for a couple of times, then it did the same thing again. I am thinking it is not the trunk lock actuator doing this. I checked wires for any loose connections, and found none. If the fuse blown, it won't work at all. Any one have an ideas what this might be? Pls help. I search, but nothing specific. Thank you in advance.
Old Feb 21, 2013 | 10:34 AM
Mr Jokster's Avatar
Mr Jokster
when you unlock the doors, do they ALL unlock and open no problem? With my car, one of the actuators is bad, I've noticed that when it gets stuck, it affects how it locks and unlocks the other doors. Maybe the problem is bleeding to the trunk actuator. Just my 2 pennies of info...
Old Feb 21, 2013 | 12:35 PM
ivnnln's Avatar
ivnnln
When I remotely unlock using all the doors unlock fine, it's just the trunk did not unlock. I have to manually unlock. I am going to pull the ECU fuse either location at inside or under the hood to see what happen next. Will report back. Thank you.
Old Feb 21, 2013 | 01:08 PM
1sWt2GS's Avatar
1sWt2GS
there is a pin that holds down the trunk lock,. that pin might be broken
Old Feb 21, 2013 | 04:40 PM
ivnnln's Avatar
ivnnln
I replaced the used lock and also replace the new pin. I will remove the cover and take a look again if the pin is in tack. Thanks.
OilMemes
RX - 1st Gen (1999-2003)
14
Aug 15, 2018 11:55 AM
djyoshi626
IS F (2008-2014)
Aug 28, 2017 02:30 PM
atomarchio
RX - 3rd Gen (2010-2015)
23
Apr 17, 2013 07:30 PM
Onoyme
Jun 8, 2008 02:33 PM
DlaxMan3
Oct 30, 2004 11:14 PM
