when i roll my driver window up with the auto one touch it stops about 4 inches from the top then rolls back down 3 inches. also i read on the forum that i could disable my drl by using the toyota/lexus scan tool. however i tried that i found many options to change exit entry light climate control and more. but none for the drl. any one have a fix for this? thank you in advance
Dont use it anymore!!!!! My passenger window did that and about 2 months ago it got stuck down for a week. it finally went back up but i havent used it since then. i cant find any info on why this is happening or what the problem is.
Inside the door panel there's a black square box labeled ED MPX door Toyota. That's most likely the issue. Same thing happens with my window and I swapped out that box and worked normal.
Sweet! i will definetly try that!!! Where would i get the replacement part for it?
Lexus or toyota dealer?
