I recently just got the iJDMtoy DRL (http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r1.htm) I'm trying to install it but its not working, but when I pull back on the high beam switch it works? I also put the halogen bulb back in now my drl doesn't work only when I pull back on the switch. what can be the problem?
Pulling back meaning your High Beams are turning on and not the DRL .. isnt our DRL the little bulbs in the high beam housing and not the same bulb as the high beam bulb ?? Correct me if i'm wrong. hope you figure out the solution.
so your drl halogen drl doesn't work? did you check BOTH fuse boxes, there's a big one close to the battery, AND and smaller one on the drivers side. When tired the CRAPPY V LED it kept blowing the fuses in the smaller fuze box on the driver side, I don't remember exactly but I think its the DRL or one of the light fuses. I would check that.
heres my experience with both V led and I love Jdm here
