Something Arching...Need Help!
Old Jul 18, 2012 | 05:40 PM
drastic95's Avatar
drastic95
Default Something Arching...Need Help!
Hello all, Im at the end of my rope here with this problem and am hoping that someone could lead me in the right direction. The whole thing started when i changed my valve cover gaskets. While I was in there I figured I would change the plugs and wires also. I bought Denso Irridium plugs and I believe it was beckley Arnley wires from Advanced auto parts. While changing the wires the two wire clips broke while unbloting it. I put the car back together and when I started it I saw a wire was arching. I figured it was because of the two clips so I bought two clips from lexus and put it in. The problem slowed down but didnt stop and got progressively worse. I then opened it back up and saw that a clip that went on to one of the coilpacks was looking very brittle and barely holding on so I bought new clips from Lexus and installed them. Still the arch. Today I opened it back up again and looked everything over and the only thing I could think of is the aftermarket wires could be bad or one of the coilpacks are bad. Feel free to chime in. I feel at this point if I take the car to a shop that all the work that I have done would have been in vain. I wont let this beat me....HELP
Im not actually seeing the arch becasue the throttle body is covering it but I hear the click and see the voltage drop
Old Jul 19, 2012 | 06:26 AM
drastic95's Avatar
drastic95
I now see that the arch is coming from coil pack number one (one closest to you when you open the hood). Does this mean that the coil pack is bad?
Old Jul 19, 2012 | 06:54 AM
Blanco's Avatar
Blanco
I would think so.
Old Jul 19, 2012 | 09:23 AM
GS4_Fiend's Avatar
GS4_Fiend
Assuming u got a gs300, change the ignition wires first.
Old Jul 19, 2012 | 09:35 AM
drastic95's Avatar
drastic95
I changed them this morning. Is there a way to test the coil packs before I purchase one? It is a 2003 Gs300
Old Jul 19, 2012 | 11:39 AM
Debonair's Avatar
Debonair
Ohm them out.
Primary:
COLD: .33-.52
HOT: .42-.61
Secondary:
COLD: 8500-14700
HOT: 10800-17200
Attached Thumbnails Something Arching...Need Help!-igpri.jpg   Something Arching...Need Help!-igsec.jpg
Old Jul 19, 2012 | 02:14 PM
drastic95's Avatar
drastic95
Wow....thanks
sw1511
Mar 24, 2023 05:21 PM
Rokas
Jul 9, 2018 02:23 PM
ComponY
GS - 1st Gen (1993-1997)
34
Oct 30, 2014 09:31 AM
1uzDreamSC
Nov 1, 2013 01:00 AM
Dtwillis5
15
Feb 27, 2011 01:19 PM
