Stereo upgrade but utse standard Unit.. Please help.
Hi all! i have upgraded all speakers and running a mono amp for sub and 4channel amp for speakers, All filters etc and xtra battery! Problem is that i gona use the standard unit for now but cant figure out the connections and gettin low voltage or that out! Is there any converter for stock units??
Have had no sound in car for month:/
You should be grabbing the signal after the factory amplifier. Therefore the color wires may not necessary be the same as these - http://www.the12volt.com/installbay/...tail/1277.html
Depending how many inputs your line converter has, I would grab full signal from a front and a rear speaker. Then use a separate crossover or the one built into your amp to split out the signals to the speakers and subwoofer.
HU -> Fac. Amp -> Line Converter -> New Amp(s) -> New Speakers
i have a processor right now but ive used loc before to get signal to my amps.
i used two locs. a 4 channel one for speakers and a 1 channel one for the sub. i got the signal from the factory amp. which is directly behind the glove compartment.
there are 2 wiring harnesses on the amp that contain the necessary wires for all four speakers and the sub as well. just tap into those. but there is definitely a separate signal for the sub that u can grab to get better sound quality. if not u can grab the 4 channels from the factory amp and then grab the subwoofer signal right from underneath the sub in the trunk.
http://www.caraudio.com/forums/car-a...xus-gs300.html
This is my build link from a couple yrs ago
There's a couple pica of the amp and connections I took from it in there
Check it out
Check it out
mcsddd
Dec 17, 2012 02:11 AM
lex8000
Jul 12, 2012 07:12 PM
nu4lexus
Jul 12, 2011 03:53 PM
Lex*Toy
May 3, 2007 08:37 PM
