HELP! What tools do I need to replace 2nd Gen GS400 Upper control arms?
Hello all CL members!
I now found out that both of the upper control arms on my 99 GS400 NEED TO BE REPLACED but I have no experience of DIY.
Please guide me with all the TOOLS needed to get the job done..
Also if any member have done this before with new parts, do the new parts come with bushings?
I will buy 2 new upper control arms that I know they come with ball joint but not sure if bushings will be included.
is there is a DYI for upper control arms in this CL please provide me the links or any member has instructions that can help me is greatly appreciated.
Jack up car and secure with jack stands
remove wheel
Remove UCA cotter pin
remove 14mm socket
Use Ball Joint puller to remove UCA from spindle
use 14 mm (i think) wrench to remove the 2 bolts holding the UCA.
remove wheel
remove 14mm socket
think thats it
The nut after the cotter pin is a 17mm nut.
If you cannot get your hands on a ball joint pull, just take a hammer to the upper control arms a few times and it will separate.
remove wheel
remove 14mm socket
