Lets talk built tranmissions....
Whats up guys. So I'm sure some on you know about the compression issue that we found on my GS after I bought it. So we are going to fix it by going GTE bottom end, its at the machine shop now getting done. Anyways so my thought is that after I get the GTE bottom end in, the motor should be able to handle 550-600whp easily. But we all know that the weak point is the tranny, so I'm trying to see what is out there for built transmission options for the 2GS without swapping to a supra 4spd auto...Has anyone built there stock one or bought one somewhere? Also any ideas on cost? The other thought is to do a R154 swap but I believe that a built auto would be the cheaper way to go....What do you guys think?
https://www.clublexus.com/forums/per...er-levels.html
Look at JeffTsai 's build info. He's done a ton of research / build work and has been kind enough to share extensively.
