JDM window visor install
Old Jun 4, 2012 | 07:52 AM
  #46
richodisho's Avatar
richodisho
/\...... visors and car look good ... nice work!
Old Jun 4, 2012 | 12:10 PM
  #47
GS4_Fiend's Avatar
GS4_Fiend
Nice pic. How did you installed urs?
Old Jun 4, 2012 | 01:12 PM
  #48
Lextasy671's Avatar
Lextasy671
...thanks guys, those were just cell phone pixes. hahaha. anyway, i tucked those downward clips underneath the rubber and lined up the stickies with the rubber.
Old Jun 4, 2012 | 01:21 PM
  #49
GS4_Fiend's Avatar
GS4_Fiend
Hey thanks for the response. It make sense to tuck the clips underneath the rubber, but when I close the door, they will bend. That's normal right?
Old Jun 4, 2012 | 02:06 PM
  #50
abounly's Avatar
abounly
It shouldn't bend. Which part are you connecting it to? It is the rubber piece on the OUTSIDE of the door right between the window and the frame of the door (or the chrome piece i believe)
Old Jun 4, 2012 | 02:24 PM
  #51
GS4_Fiend's Avatar
GS4_Fiend
The chrome piece trim is on the body of the car. This is how i did it. I open the door. Pull the the rubber trim towards the car. Then i slide the visor's clip, which is pointed downwards, onto the door trim. Then push the rubber trim down to secure. Then when i close the door, the clips gets bent and my visors moves up a little. I hope im making sense. Keep in mind i havent removed the tape yet. Is that the reason my visors are popping up when i close the door?
Old Jun 4, 2012 | 02:47 PM
  #52
abounly's Avatar
abounly
Oops I thought about it, and the chrome trim is on the car itself. Hmm I would try to take a picture of the trim where the clip is suppose to be but my visors are already on.
It probably pops cause the tape isn't on but it doesnt explain the bending of the clips and it shouldn't move up.
Old Jun 4, 2012 | 03:12 PM
  #53
GS4_Fiend's Avatar
GS4_Fiend
I will post a picture of how i did it. Thanks
Old Jun 4, 2012 | 03:29 PM
  #54
Lextasy671's Avatar
Lextasy671
just stick the damn thing on already. hahahaha! as for bending, i dont get any bends when the doors close, so im thinking u get the bends cuz it isnt sticked on yet. just make sure u align them cuz once u stick it on, dats it..
Old Jun 4, 2012 | 08:45 PM
  #55
GS4_Fiend's Avatar
GS4_Fiend
Ya, i think that's probably why because I haven't removed the tape yet. If it's just a matter of side the clips down and tape then it does sounds easy. The confusing part was I thought i was suppose to hang the clip onto the door trim. But in this case, the clips are opposite, you cant hang them but instead you slide it under the door trim and then tape. Thanks guys.
Old Jun 10, 2012 | 01:35 PM
  #56
GS4_Fiend's Avatar
GS4_Fiend
I notice, the double sided tape, sits higher than the rubber trim. Is it suppose to be like that? Since the clip doesn't allow the tape to be lower than the rubber trim.
Also, I can't get the front visors to stay below the chrome trim near the slim end why is that?
This sucks lol.
Attached Thumbnails JDM window visor install-img_0129.jpg   JDM window visor install-img_0128.jpg
Old Jun 10, 2012 | 07:48 PM
  #57
SSxblazer's Avatar
SSxblazer
Difference between JDM and the ones off ebay or at an auto parts store?
thanks
Old Jun 10, 2012 | 10:46 PM
  #58
GS4_Fiend's Avatar
GS4_Fiend
Mines are JDM...
Old Jun 11, 2012 | 02:30 AM
  #59
abounly's Avatar
abounly
You see the end of the visors where it bulges out? Its suppose to sit flushed with your mirror piece. Here i'll take some pictures since i dont want to study for my finals.
2nd picture, you are trying to mount it onto the door's rubber trim that goes around the whole door, you don't want that piece.
You're mounting it too high. It is not suppose to block the chrome strip.
You're currently mounting it on this plastic trim, which is incorrect.
You want to mount it on this trim instead
Just follow it up.
Old Jun 11, 2012 | 09:19 AM
  #60
GS4_Fiend's Avatar
GS4_Fiend
I really appreciate your effort for posting this. I thought i was suppose tape the visors on the rubber trim instead of the window trim. So basically, if i do it your way, where am i hooking up the clip? The reason why mines is buldging is because the clips are higher than the other which got me frustrated. Sorry for being a noob
Just follow it up.
