Upper rad hose slides back a few mm. Is this this normal? PICS
Old 10-19-11, 04:40 PM
chuckb
chuckb's Avatar
Default Upper rad hose slides back a few mm. Is this this normal? PICS
Car is 01 GS430 71k miles. I moved it forward and it slides back to where the pics show. I dont understand why. Its not leaking and it seems to stop when it hits the lip on rad. dont know if its always been like this or if I just noticed it. I thought maybe the stock preloade clamp got tired so I put on a regular clamp but it still does it. Car doesn't run hot or boil over into overflow. last pic shows where it I put it before it moves.
Old 10-19-11, 04:42 PM
Och
Och's Avatar
Weird, just noticed the same problem with mine as well. Bought a hose clamp at autozone, tightened the living crap out of it, and it seems to stay in place now.
Old 10-19-11, 04:47 PM
ThomasGS4
ThomasGS4's Avatar
Sign of motor mounts going bad?
Old 10-19-11, 04:49 PM
chuckb
chuckb's Avatar
regular clamp seemed to help mine a little but I'm leery tightning the crap out of it because the rad is plastic....
Old 10-19-11, 04:59 PM
chuckb
chuckb's Avatar
Doubt it & also mounts were replaced once already under warranty.
Old 10-19-11, 05:08 PM
Och
Och's Avatar
Check your radiator cap. When I discovered my hose was sliding off, I removed the cap, and found that the bottom piece broke off (and is roaming through my cooling system somewhere). Just wondering if its a coincidence.
Old 10-19-11, 05:09 PM
GS4_Fiend
GS4_Fiend's Avatar
That factory clamps sucks. If you can, get the hose clamp that you can tighten it
Old 10-19-11, 05:12 PM
TWong350
TWong350's Avatar
I wouldn't sweat it. As long as you have that clamp on their, it won't get by that 'lip' on the radiator outlet.
Old 10-19-11, 07:31 PM
GS4_Fiend
GS4_Fiend's Avatar
There was a guy with a black gs400 with Works T1S had his hose slipped off. Fix it before it happens.
Old 10-19-11, 09:53 PM
sjlexus408
sjlexus408's Avatar
I also think its a sign that the motor mount is going bad, mine does the same thing and I know my mounts are bad.
wirelesstj
SC- 1st Gen (1992-2000)
15
12-22-12 06:29 PM
Tommy2JZ
07-03-12 09:06 PM
grindin8o8
Performance & Maintenance
13
07-25-09 10:20 AM
maniax
08-02-06 05:58 PM
Quick Reply: Upper rad hose slides back a few mm. Is this this normal? PICS
