Quick alignment question regarding rear toe
Old Sep 27, 2011 | 05:38 PM
e-man's Avatar
e-man
Default Quick alignment question regarding rear toe
Hey guys. I'm having an alignment issue on my 99 GS4 with 175,000 miles.
I had an alignment done last week and Lexus told me that my right rear corner was -0.15 toe out. I believe this happened when a used car appraiser hit a pothole while test driving my car (whch is another story for another day).
Anyway, in doing the alignment, Lexus told me that they couldn't get the toe on the right rear corner to exactly zero because the alignment bolt was rusty and stuck when it got to a certain point and they couldn't go any further. They said they were able to get it to 0.01 (positive, not negative).
Here are my questions:
(1) It seems to me that if the corner was previously -0.15 degrees and they were able to adjust it to 0.01 (positive) that they actually bypassed zero and went a little too far. Is that accurate? Can you get to 0.01 from -0.15 without passing zero?
(2) What effect, if any, would positive 0.01 on the right rear corner have on the tracking of the car? If the toe is slightly in on that corner, would it cause the car to track right or left (if at all)?
Thanks for your help.
e
Old Sep 28, 2011 | 04:32 AM
tn96dc's Avatar
tn96dc
At 0.01, it is within specifications. What is the measurement on the left side? That one hundred of a degree shouldn't make it pull much.
Old Sep 28, 2011 | 08:04 AM
e-man's Avatar
e-man
Thanks. The measurement on the left rear side is 0 (as is the measurement at both front corners). Would I be better off asking them to put the left rear corner at .01 so that they match?
Also, am I missing something as to why they can't get it to 0? Wouldn't they have had to pass by 0 in going from -0.15 to +0.01?
e
Old Sep 28, 2011 | 08:12 AM
GSteg's Avatar
GSteg
Yes you would have to go through zero in order to go from toe out to toe in.
I wouldn't worry about 0.01 vs 0. What's important is cross toe and from the looks of it, your car is fine. Just having the driver sit in the car already changes the alignment parameters.
Bender25
Mar 13, 2012 07:27 PM
flektone
Suspension and Brakes
Jun 24, 2011 09:50 AM
skirts
Jul 7, 2010 08:09 PM
bishop977
Maintenance
Jun 15, 2004 10:16 AM
csr
Oct 9, 2002 09:55 PM
