Help me locate yaw sensor
Old Aug 13, 2011 | 05:38 PM
Yum's Avatar
Yum
Default Help me locate yaw sensor
Hey guys I own a 1998 GS300 Lexus and I would really like your help in locating the yaw sensor. Also did a diagnostic check and got the code C1233, does any have info on this please help urgently.
Old Aug 13, 2011 | 05:50 PM
Chin's Avatar
Chin
Former Sponsor
The part number is 89183A. It's located under your shifter/center console area.
Old Aug 13, 2011 | 11:05 PM
Debonair's Avatar
Debonair
This is an ABS/VSC system code. C1233 means either the Zero Point Calibration (ABS system / Yaw sensor) has not been done or the voltage coming out of the sensor is out of spec.
Have your repair person run the calibration. If it fails to correct the issue, or will not complete replace the sensor.
Old Aug 14, 2011 | 12:43 PM
Yum's Avatar
Yum
Thanks guys for your help. Hey Debonair I would like to know how does one run the calibration, can you give a general rundown of how this is done.
Thanks.
Old Aug 14, 2011 | 02:45 PM
porn-adkt's Avatar
porn-adkt
Thanks.
Zero calibration is not something you can do without the proper equipment. However there is a Jumper method Via the DCL3 port on the repair manual, its been posted on previous threads.
I believe the Yaw rate is located underneath the front arm rest console
Old Aug 14, 2011 | 02:51 PM
GS4_Fiend's Avatar
GS4_Fiend
Here ya go buddy
https://www.clublexus.com/forums/mai...c-problem.html
Old Aug 14, 2011 | 03:56 PM
Debonair's Avatar
Debonair
Thanks.
As far as I knew using a capable scan tool (factory or other high end) was the only way to perform the Zero Cal. But based on the other replies here there is a manual method. Have a go at it and check back.
Old Aug 15, 2011 | 10:49 AM
Chin's Avatar
Chin
Former Sponsor
Here's my good deed for the day...
Attached Thumbnails Help me locate yaw sensor-imag0297.jpg   Help me locate yaw sensor-imag0298.jpg
joegreen
19
Jul 15, 2015 11:44 PM
mortirius
Jul 28, 2012 03:40 PM
Yum
GS - 1st Gen (1993-1997)
Aug 13, 2011 02:07 PM
hksnlper
Mar 16, 2007 06:53 AM
