information on fixing your broken door lock actuators with new OEM toyota actuator
Old 02-07-11, 11:49 PM
alexdan
alexdan's Avatar
what would be a good donor latch for a switch ....possible from other toyotas??
Old 02-08-11, 07:08 AM
lexus ASM
lexus ASM's Avatar
anything that has a micro switch the same size. I used an old gs400 latch.
Old 02-10-11, 11:12 PM
g1kon1whee
g1kon1whee's Avatar
deleted more
Old 02-16-11, 05:33 PM
billzblaze
billzblaze's Avatar
wonder if the avalon act would work for the driver side also?
Old 02-16-11, 05:40 PM
g1kon1whee
g1kon1whee's Avatar
deleted more
Old 03-08-11, 04:47 AM
Blanco
Blanco's Avatar
I'm a bit confused after reading this thread. I too have rear door problems. What's the proper solution?
Rear Passenger door: does not unlock or lock by power. Has to be manually manipulated. Not sure on the status of the lights. When the door is open, I'm pretty sure the door ajar light is NOT on.
Rear Driver door: Works when power is applied. Door light, and courtesy light both come on. Dome light is intermittant at best. While I had door open, the alarm armed this morning getting stuff out of my back seat. Pretty sure it also does not trigger the door ajar light in dash.
Do I need a whole new assembly for the passenger side door? What about the driver side. I just want everything to work like it's supposed to. Would the door ECUs have anything to do with this?
Old 03-09-11, 03:35 PM
btanchors
btanchors's Avatar
What are dealers charging to fix this? I have two doors on my 2003 GS430 with this problem. I don't have the time or patience to fix it myself, and am wondering how much I should plan to spend to have the dealer fix it?
Old 03-09-11, 03:46 PM
g1kon1whee
g1kon1whee's Avatar
deleted more
Old 03-09-11, 03:47 PM
g1kon1whee
g1kon1whee's Avatar
deleted more
Old 03-09-11, 03:48 PM
btanchors
btanchors's Avatar
Driver's side front, and passenger side rear.
Old 03-09-11, 04:13 PM
g1kon1whee
g1kon1whee's Avatar
deleted more
Old 03-14-11, 08:39 AM
hmt
hmt's Avatar
I have 01 GS430. When I bought it 6 months ago everything was fine. Recently the Front driver door lock stopped working. It only works manually. Not with remote nor using unlock inside the car. That means the actuator is bad, doesn't it? I called Lexus dealer to check on the price and they'd charge me ~$500 for 1 door (both labor and part). They can't just replace the actuator. They have to replace both the actuator and motor...:~(....
Hope this helps and can someone please confirm this is the actuator problem that I have before I order the part...
Many thanks....
Old 03-14-11, 10:10 AM
kuWuPt
kuWuPt's Avatar
man, saw this thread too late I guess I could've tried getting the Avalon actuator to see if it fits. Ordered an actuator last week came in on Friday and replaced it. Door closes with a fresh thud now . Where in NC are you man, if you are around the triangle I could possibly help you out. PM if you need anything..
Old 03-14-11, 02:13 PM
pinoiryder
pinoiryder's Avatar
Many thanks....
I have the same problem.. anyone can confirm this is the problem?
Old 03-30-11, 07:27 PM
ksultan78
ksultan78's Avatar
classic case of the actuator motors going bad...
https://www.clublexus.com/forums/gs-...epair-diy.html
and
https://www.clublexus.com/forums/gs-...ators-diy.html
can help you fix the issue
Rar17
02-27-19 01:59 PM
whitecel
02-12-14 08:40 AM
bdevlin197
07-04-11 07:33 AM
ZeekGS300
04-20-07 07:36 AM
gs300inky
Maintenance
10-05-04 02:48 PM
Quick Reply: information on fixing your broken door lock actuators with new OEM toyota actuator
