What the.......
Old Nov 15, 2010 | 12:39 PM
100bajan's Avatar
100bajan
Default What the.......
ok so this evening I went to close my sunroof and it closed all the way........then opened back up a quarter of the way!!!!!!!!!! What is going on????
Old Nov 15, 2010 | 01:11 PM
D-Boi's Avatar
D-Boi
my drivers side window does the same thing, i have to keep the button pressed for it to fully close it wont work with the one touch feature.
Old Nov 15, 2010 | 03:37 PM
NIXmx's Avatar
NIXmx
There was a TSB about this.
Old Nov 15, 2010 | 03:49 PM
Mr Jokster's Avatar
Mr Jokster
Yea, I have the same problem. It happens every once in a while, I think there may be something catching the sensor (like a garage door opener) and it thinks something is in the way, so it opens back up for safety... All you have to do is right before its about to close all the way, lightly push up with your finger on the back side of the window very close to the edge (helping it close) doesn't take much pressure, and it goes up no problem. Probably wont have the problem again. It's happened just a few times on me.
the other guess, is that there may be a problem with the actual switch, but since the finger thing works [for me] I dont think so now go try it
Old Nov 15, 2010 | 06:34 PM
100bajan's Avatar
100bajan
Well the car was parked for a few hrs with the Sunroof partially opened, and when I started it and said my prayers it closed...lol...so now I am scared to open it and have it stick again..LOL
Old Nov 16, 2010 | 02:03 AM
Lextasy671's Avatar
Lextasy671
ive experienced that with my IS250 before...lucky i had homies who are Lexus techs at the dealer...it has something to do with programming. i never asked, but i watched my friend do some "holding the **** there for a few seconds" thing and it was good.
Old Nov 16, 2010 | 03:32 AM
Mr Jokster's Avatar
Mr Jokster
My one finger solution works just fine
Old Nov 16, 2010 | 08:29 AM
oysgs430's Avatar
oysgs430
I had this happen to my passenger side window i checked and the window gasket was loose i just pushed it back into place and it close just fine now
Old Nov 16, 2010 | 08:34 AM
sakataj's Avatar
sakataj
i have a spare switch if anyone needs one
Old Nov 16, 2010 | 09:08 AM
7wolf's Avatar
7wolf
it may just be out of timing. push the button to open the sunroof and hold it till it opens all the way. the push the button to close it and hold it closed till it closes all the way, still holding the button closed. the sunroof will open again, close again, tilt open, tilt closed and then stop. (you were still holding the close button the whole time). the one touch should be fixed. if it's not, see your dealer, lol.
Stereorob
Jul 1, 2016 01:25 AM
Murasumi
Jun 20, 2009 11:23 AM
kuzbayne
RX - 1st Gen (1999-2003)
May 23, 2007 12:48 AM
bmgs400
Mar 28, 2006 01:29 PM
gk808
Aug 10, 2004 02:45 PM
