What are struts.
Struts are similar to shock absorbers in nature. Struts are usually bolted to the side of either the suspension, or the vechile's wheel well. Where as shocks are usually attached to the upper shock tower to the lower part of the spring or control arm. Hope this helped.
Left pic is what a shock looks like and next to it is a strut.
http://www.monroe.com/Europe_Japancars.htm
Shocks and struts are safety components that maintain vertical loads placed upon the tires. They control spring and suspension movement to keep tires in contact with the road.
Originally posted by VVT-i
jmai22.. you probably win the most threads award by now.
jm,
its kinda odd how you apparently like and probably know a whole lot about car audio, but little about basic vehicle components. not to be rude since i'm almost in that same boat.
i figure if your into car audio, you're usually into cars completely. if not, at least your getting there
TRoyals14
Nov 24, 2005 09:59 PM
SLVRGS
GS - 1st Gen (1993-1997)
Mar 3, 2003 11:38 AM
