New rear diff install!!
Old Oct 29, 2010 | 08:01 PM
98Gs4001UZ's Avatar
98Gs4001UZ
Default New rear diff install!!
Hey guys just got my Gs300 rear and it ready to be installed in my gs400. I'm pretty excited I've been waiting for this for weeks. Is there anything I need to know about the install before I start? I hear it just bolts in but it's usually not that easy. I'll post updates as soon as I complete the install.
Old Oct 29, 2010 | 08:23 PM
TLcoats's Avatar
TLcoats
Yeah it's a pretty difficult install if you don't have power tools. I had my mechanic due it because i had trouble getting the bolts un torqued. Just make sure to use some loctite just in case. But the 3.92 gears work perfect for this car. I love the new gear ratio!
Old Oct 29, 2010 | 08:29 PM
98Gs4001UZ's Avatar
98Gs4001UZ
Yeah I'm a dodge diesel tech I got plenty of power tools and access to lift so that should make things easier. Thanks for the info.
Old Oct 29, 2010 | 08:32 PM
TLcoats's Avatar
TLcoats
Yeah your good to go then! Enjoy the new gears man, they make a great difference! Oh and you have to unbolt the middle section of the exhaust for the diff to drop down. It's pretty obvious but just wanted to let you know.
Old Oct 29, 2010 | 08:46 PM
98Gs4001UZ's Avatar
98Gs4001UZ
Awesome thanks. What about the where the axle shafts bolt to the diff are those the same? Or do I have to swap them for one diff to the other? Same with where the drive shaft bolts to the diff?
Old Oct 29, 2010 | 10:19 PM
speedaddic's Avatar
speedaddic
Pretty straight forward install. I did it without power tools, just a big breaker bar.
Old Oct 29, 2010 | 11:21 PM
TLcoats's Avatar
TLcoats
Everything is the same. Simply swap and play.
Old Oct 30, 2010 | 06:19 AM
98Gs4001UZ's Avatar
98Gs4001UZ
Awesome that's alot. That makes everything easy now. I should have it in by lunch time today.
Old Oct 30, 2010 | 06:42 AM
benbuilt4u's Avatar
benbuilt4u
took me 45 minutes to do mine at work. just remember you need a 12mm allen wrench.
Old Oct 30, 2010 | 02:57 PM
98Gs4001UZ's Avatar
98Gs4001UZ
Ok the rear diff is finally installed after 1h and 18m!! It runs great! Such an inexpensive upgrade (well if you do it
Yourself) and the difference is very noticeable. Thank you guys again for the advice before I started this project.
Old Oct 30, 2010 | 03:30 PM
TLcoats's Avatar
TLcoats
Wow! My mechanic charged me 3 hours... Enjoy the upgrade!!
Old Oct 30, 2010 | 04:22 PM
100bajan's Avatar
100bajan
I am a real novice and I am hopefully getting a GS this week, I want the 400 so my question is what advantage do I get from using a 300 rear differential?
Old Oct 30, 2010 | 04:45 PM
TLcoats's Avatar
TLcoats
The stock GS400 gear ratio is 3.23. The stock GS300 gear ratio is 3.92. So basically you get a higher gear ratio so your rpm's are higher at any given speed increasing low end speed and torque. It also helps city driveability since your always in the torque curve. But you do lose some MPG's on the freeway since your revving at about 3k at 80MPH
Old Oct 30, 2010 | 05:48 PM
98Gs4001UZ's Avatar
98Gs4001UZ
Wow he made his money for sure :/ . Yeah I very much in enjoy it.
Old Oct 30, 2010 | 05:53 PM
98Gs4001UZ's Avatar
98Gs4001UZ
Yup was doing 80 and it was about 3k. Which really isn't that far off from what I was running before. 50 mph I was at 2k and now I'm at 2200 not that
Bad of a difference, but as for as torque and power you can definitely feel the difference
