Serpentine Belt gs300 help..
A good video of how to do this and the pulley location and the movement required is here, at 2:30:
http://www.youtube.com/watch?v=-fiHr...eature=related
To put the belt back on, there is a sticker either on top of the radiator (directly in front of you as you are looking at the engine) or on the left side of the under side of the hood. It will tell you the placement of the pulley. It's a bit awkward to get it on sometimes. I recommend looping the belt around, then pulling the belt through between the water pump and the crank as the last loop, then retensioning it.
Oh, and you don't really need a huge breaker bar like Jeff uses, a long wrench works just fine, you just gotta push hard. It's really not difficult to do at all.
03, 1995, 2006, 300, belt, change, difficulty, gs, gs300, lexus, lexusclub, number, replacement, serpentine, serpintine
