Squeaky noise
Old Aug 23, 2010 | 05:00 PM
airahcaz's Avatar
airahcaz
Default Squeaky noise
Sorry for the naive question, but I hear creaky noises, more prominent when going over bumps. Do I need new shocks/struts or can I lubricate something?
Lastly, could it be something totally different?
98 GS 400
Old Aug 23, 2010 | 05:03 PM
rgarjr's Avatar
rgarjr
balljoints maybe?
Old Aug 23, 2010 | 05:06 PM
Anthony's Avatar
Anthony
are you on stock suspension?
Mr Jokster's Avatar
Mr Jokster
could also be bushings worn out. you know like how your sneakers begin to squeak when they begin to crack on the inside
Old Aug 23, 2010 | 05:08 PM
porn-adkt's Avatar
porn-adkt
Your question like many other from CL members is so Vague, its hard to begin to try to help you. jack up the car,take wheels off, do some investigating, and post your questions, even better if it has pics. Or take it to a mechanic
At this point could be anything.
airahcaz's Avatar
airahcaz
Balljoints were replaced two years ago. How do I get bushings checked?
Old Aug 23, 2010 | 05:12 PM
airahcaz's Avatar
airahcaz
Yes stock suspension
Old Aug 23, 2010 | 05:31 PM
Mr Jokster's Avatar
Mr Jokster
gotta try to reproducing the sound while not driving, thats where you start. Once you can reproduce it, you can have yourself or someone try to narrow down where its coming from. Get a long hose of some type to use as a stethoscope to see where its coming from. I think it may be a bushing thing. But just a guess on a vague description
How to reproduce: which ever side its coming from, push down on the car and make it bounce to see if that will do it.
Old Aug 23, 2010 | 05:58 PM
Frankdorn's Avatar
Frankdorn
I have this, too! You can really heard the squeaking on a hot day when I pull in the driveway. Sounds like the car has arthritis and rubber is sqwacknig against something. On cool days it's not as bad...
I'm on stock shocks, Eibach springs...
Old Aug 23, 2010 | 06:07 PM
VipDout's Avatar
VipDout
19x11.5 -51
I just placed an order for upper A Arms with joints.... Started hearing the noises today and I know its due
Old Aug 23, 2010 | 06:13 PM
airahcaz's Avatar
airahcaz
Yes pushing down on the car creates the squeak
Old Aug 23, 2010 | 06:23 PM
Mr Jokster's Avatar
Mr Jokster
thats a good start. now try to narrow down exactly where its coming from
Old Aug 23, 2010 | 08:12 PM
ThomasGS4's Avatar
ThomasGS4
Heh...my car does this too.
Getting new shocks/springs installed shortly. Probably time for UCA's too.
Old Aug 23, 2010 | 08:31 PM
MrEH2's Avatar
MrEH2
sounds like the same problem im having...its the top hat strut nut/bolt..the one right in the middle, tighten it with a impact and push down on the side that is squeaking...
if it helps then thats the problem..i havent gotten around to replacing the nut itself yet so i dont know if its the nut that is bad...but give that a ****
Old Aug 23, 2010 | 08:41 PM
Mr Jokster's Avatar
Mr Jokster
give that a what? I tried replacing those asterisks with every 4 letter word I know... and none fit LoL
