1999 GS 300 Starting problems..
Old Jul 26, 2010 | 09:34 AM
WEAVER99's Avatar
WEAVER99
Default 1999 GS 300 Starting problems..
I have a 1999 GS 300 and here in the past 2 weeks or so, whenever I go to start the car, all I hear is a click sometimes. Sometimes It will click like 3 times or so in a row then it will finally start, and sometimes it will start right up. Sometimes I've noticed as well that it seems like it barely wants to start like a low voltage situation, then it starts.
I took the battery connections off last night and cleaned them from the corrosion, but it still does it. The battery is about a year old. Any ideas on what might be the problem? Thanks
Old Jul 26, 2010 | 10:23 AM
wbmx1981's Avatar
wbmx1981
I had the same problem and my issue was the starter. Goodluck.
Old Jul 26, 2010 | 10:35 AM
toy4life86's Avatar
toy4life86
sounds like the starter is going bad to me too sometimes you can hit the starter to get some more life out of it, worked on my tacoma i had a bad starter for 2 months , it was a manual so if it didnt start than id just push it down a hill and start it
Old Jul 26, 2010 | 10:47 AM
PushinLEX's Avatar
PushinLEX
it's probably the starter. i have a 99 GS and my starter went out last summer. just have it rebuilt. i had a local shop rebuild the factory denso for like $110. i think the stealership will charge you around 500-600 for a brand new one.
Old Jul 26, 2010 | 10:50 AM
vwynn's Avatar
vwynn
you can also rebuild the starter for a whole lot less by replacing the contacts.
Old Jul 26, 2010 | 11:12 AM
cxp2001's Avatar
cxp2001
Yes,, It is the starter.. I had the same problem on my 99 GS. It got worse over time and finally left me stranded..I thought it was the battery cables at first.
Old Jul 26, 2010 | 11:23 AM
WEAVER99's Avatar
WEAVER99
Thanks for the help guys. Sounds like we all had the same situation.
Did any of you take it out by yourself, or is it a real pain?
As far as the starter contacts, do you have a link as to what I would need to get? Does this seem to be the problem a lot of times?
Old Jul 26, 2010 | 06:58 PM
toy4life86's Avatar
toy4life86
I think its in the DIY but seems preety hard not an average task
Old Jul 26, 2010 | 07:27 PM
cxp2001's Avatar
cxp2001
I payed to have mine installed. It cost $85.00 to install it. Mine failed on me and I had the car towed to the show. But I had the part in my trunk..
Old Jul 28, 2010 | 09:17 AM
big1236's Avatar
big1236
Hey guys- Is this the same problem I'm having?
Okay, sometimes when i put the key in and turn on the engine, nothing happens-no lights will turn on, it'll 'start' but then die, it's like a need a jump or something.
I take the key out and put it back in and when i turn the key, it's like nothing ever happened. the car starts like normal and it purring the a kitten. WTH?
dkillrstr
Sep 1, 2014 08:24 PM
stk7741
Sep 12, 2011 01:19 PM
IBeBofa
Apr 24, 2009 10:11 AM
demon1
Jun 29, 2007 06:08 AM
valgs350
Aug 10, 2006 10:32 AM
