problems
Old Jun 3, 2010 | 09:48 AM
GS-power's Avatar
GS-power
Question problems
hi guys
i have gs400 2000 and i have some problems
1- some time the electricity of my car become week, when this problem hapen, if i was opeing the car stereo it shut-down and all the lights become dark. so while im driving and facing this problem i shut-down the AC to save the elec., i changed the alternator once and i got the same problem again. i noticed that when the humidity is high in the weather , the problem come again . and 2day when i started the car, the starter tooks time and i saw the gauges moving, but the gauges for feul ant tempreture gose one hole roun and stuck before the pin that holding it .
2- and i have the same problem as my friend loud3nergy "Super Wired Problem", i fix it temperory by taking it to the tech and he clean the "Throttle body", the car works fine for maybe month to to month and come again.
Old Jun 4, 2010 | 01:57 AM
GS-power's Avatar
GS-power
no one know how to solve the problem??
Old Jun 4, 2010 | 02:05 AM
Mr Jokster's Avatar
Mr Jokster
have you tried an other battery? Maybe the battery is not taking a charge and the car is running directly off the alternator. Are all your connections tight? is your belt tight? Could be loose and slipping, not spinning the alternator enough to keep a charge.
Old Jun 4, 2010 | 11:39 AM
FrankT's Avatar
FrankT
Learn how to use a cheap voltmeter and you can solve this yourself...
If you have questions post the voltage numbers here.
Without knowing what the alternator output is or what type of charge the battery holds the only thing we can do is guess.
Old Jun 4, 2010 | 02:32 PM
dejavu157's Avatar
dejavu157
^^ very smartt
Old Jun 4, 2010 | 02:39 PM
Gs430Boi's Avatar
Gs430Boi
sounds like you have an alternator problem very common on gs400
Old Jun 5, 2010 | 11:10 AM
GS-power's Avatar
GS-power
guys problem solved
the tech told me that the problem is from the fuse
i have a picture but i don't know how to upload it
Old Jun 5, 2010 | 11:44 AM
Mr Jokster's Avatar
Mr Jokster
go to "go advanced" mode in reply. and scroll all the way down and click "manage attachments" when you click on that it will open a widow to upload from your computer.
Old Jun 5, 2010 | 03:21 PM
Rich23's Avatar
Rich23
Good luck bro...
Old Jun 7, 2010 | 01:39 AM
GS-power's Avatar
GS-power
Hi guys
i faced some problems in uploading the pics,
so if someone have a problem in car electricity, i prefer to go and check the fuses (y).
good luck all
jean1982
Sep 22, 2014 11:37 PM
mvito18
Dec 13, 2010 12:13 PM
Iron Sheik
Sep 1, 2005 11:41 AM
