Fogs don't turn off??
Quick question, I did the fog light mod following BananaGS DIY. The fogs stays on no matter what when I turn the car on. When I took the white thing out underneath the steering wheel (where you tap into the wires) the fog lights are still on even though it is not plugged in. So, my question is why can't I turn on and off the switch when i plug everything back on?
Check where you tapped into the fuse box to get power and try a different spot. I dont really know about the clup under the steering wheel I had this same problem but by the time I tried it everything was back together. I just tapped into a differnt fuse.
93lexES300
Sep 16, 2008 07:44 PM
