front end clunk
Old May 24, 2010 | 10:23 AM
fastryan's Avatar
fastryan
Default front end clunk
front end makes a clunk/rattle over square edged bumps e.g. train tracks. replaced lower ball-joints and shocks. any ideas?
Old May 24, 2010 | 11:08 AM
BP_VVt-i's Avatar
BP_VVt-i
yea if you have any play in your wheels they need to be replaced. also check your struts/shocks. oh and you lower caster arms. they normally make the clunk sound the most
Old May 24, 2010 | 12:25 PM
Rich23's Avatar
Rich23
strut mounts, stabalizer links or tie rods??? Just throwing it out there... Get it up on a lift and check it out to confirm...
Old May 24, 2010 | 01:10 PM
Anthony's Avatar
Anthony
maybe you need to lube up the bushings..what shocks do you have now?
Old May 24, 2010 | 01:15 PM
sivikvtec's Avatar
sivikvtec
caster arms, either change the bushing to aftermarket or get the 03-05 updated arms (about $130/ea)
Old May 24, 2010 | 04:01 PM
fastryan's Avatar
fastryan
I got the bilstein sport shocks. Lube isnt going to get rid of this rattle/clunk. Something is moving. What are you calling the castor arm?
Old May 25, 2010 | 07:44 AM
xfea's Avatar
xfea
Hey - I just put on Bilstein Sport Shocks too (great no?)
But at the same time I replaces all the bushings.
Front sway, back sway, steering rack, and most importantly, control arm.
You have a blown caster bushing - it's the big one and the back of the lower control arm.
I had the same symptoms as you - nasty metallic clunk skimming over bumps on the freeway...etc., and a lot more.
Go to the suspension and brakes forum and search Daizen.
Here:
http://www.tmengineering.net/suspens...n/make/gs.html
Old May 26, 2010 | 07:52 AM
fastryan's Avatar
fastryan
thanks for the help. i wondered about that weird bushing.
Old Jun 21, 2010 | 05:56 AM
gcam77's Avatar
gcam77
How are the control arms different on 03-05 as opposed to the 98-02?
Are the there any issues when installing 03-05 control arms on a 1998 car?
Where can you get the arms at about $130, and are they LEXUS OEM?
Old Jun 21, 2010 | 09:56 AM
dealer374's Avatar
dealer374
Check the sway bar link/ bushings. Mine made a similiar sound when I went over all pot holes and pretty much all bumps
Old Jun 21, 2010 | 03:52 PM
chav's Avatar
chav
I am interested in the Upper Control Arm for $130 also! I had a noise in the suspension, very noticible over bumps. Upper Control Arm and Sway Bar Link x2. $903 w/ shipping from Sewell. I have seen others out there, Mevotech, Dorman, and OES. All less expensive. Anyone with experience, is there a difference? I am planning to order tomorrow and fix as soon as they arrive!
Old Jun 21, 2010 | 04:46 PM
geeznuts's Avatar
geeznuts
Check if the strut mount bolts it tight
Old Jun 21, 2010 | 05:37 PM
sivikvtec's Avatar
sivikvtec
https://www.clublexus.com/forums/sus...ml#post5011972
you can get the new arms from this site sponsor:
www.carsontoyota.com
Old Jun 22, 2010 | 07:50 AM
viapol's Avatar
viapol
Just replace the sway bar bushings.. really easy and my anoying clunk has been gone ever since.
Old Jun 22, 2010 | 09:26 AM
Newchapter's Avatar
Newchapter
I get it now but it's the brakes... Everything else has been replaced.
gorm2
Aug 22, 2018 09:45 PM
realsync1
Jul 13, 2016 10:43 PM
Finn
Nov 13, 2013 02:03 PM
D-Boi
May 8, 2010 10:44 PM
kevin.tran
Suspension and Brakes
Jul 17, 2008 06:07 PM
