What is this leaking?! Help please! (pics)
Old May 3, 2010 | 03:52 PM
UpstateLex's Avatar
UpstateLex
Exclamation What is this leaking?! Help please! (pics)
... what could this possibly be? almost seems orangeish??
Old May 3, 2010 | 04:54 PM
porn-adkt's Avatar
porn-adkt
if its ur WP then i would say its Toyota RED
Old May 3, 2010 | 05:23 PM
AshburnM3's Avatar
AshburnM3
^^^ wp is leaking
Old May 3, 2010 | 06:38 PM
UpstateLex's Avatar
UpstateLex
thanks guys, just got back from my auto savvy friends house and he did confirm that it def the wp. Just had it replaced literally like less then 2 weeks ago. looks like they used the old gasket and tried to use a gasket maker or something like that. their work is warrantied for 12 months or 1 year, do you think theyd be willing to order a new gasket and replace it under that warranty they offer?
Old May 3, 2010 | 06:43 PM
excluesive's Avatar
excluesive
they better do it. Call them and tell to get the car towed and fixed by someone competent
Old May 3, 2010 | 06:59 PM
McKrevice's Avatar
McKrevice
so instead of buying a 5 dollar gasket they use that? I have nothing against RTV if used properly.
Don't bring it back to that shop. idiots.
Old May 3, 2010 | 07:02 PM
UpstateLex's Avatar
UpstateLex
the thing is tho is that it was replaced and covered with my aftermarket warranty... and yeah i know it looks like the gasket from seweell with discount is only about $6!! im heated
Old May 3, 2010 | 07:29 PM
JeffTsai's Avatar
JeffTsai
The gasket can be reused if it is not damaged. Also, make sure that the two mating surfaces are thoroughly cleaned! Using RTV in between in the pump and housing like they did can actually cause a leak!
Old May 3, 2010 | 07:40 PM
UpstateLex's Avatar
UpstateLex
thanks for the input everybody, this really makes me frustrated.. why do a job like that and then cheap out on the gasket??
Old May 3, 2010 | 09:03 PM
McKrevice's Avatar
McKrevice
laziness.
Guy I know is an engine builder and had a customer spend 7000 on an engine, a 500 cubic inch GM for a caddy and even so it was a heavy *****, all aluminum, and refused to buy a lift plate. Tried to lift it a different way, dropped it from 5 feet up it cracked the concrete, and after inspection the shortblock got fubared up.
My guy does not load engines due to this kind of thing.
Do it right or do it twice. Someone wise said this.
Old May 4, 2010 | 04:55 AM
UpstateLex's Avatar
UpstateLex
Yup, theyll be doin it twice now. called this morning and they said bring it iin.. well see from here but im not happy and their done with my car after this.
mkubo
Dec 7, 2018 11:48 PM
kzlflash
IS F (2008-2014)
43
Jan 25, 2017 02:24 PM
Glidin316
Oct 8, 2012 06:33 PM
uplusd
May 24, 2008 06:57 AM
92_SC400
May 21, 2006 08:00 PM
