Engine knock noise
Old Apr 5, 2010 | 01:27 PM
DarKnight's Avatar
DarKnight
Default Engine knock noise
My car developed this knocking noise after about 2.5 months of almost no use. I would use the car sparingly. Here's a clip of the sound, you can start to really hear it at about 10 seconds.
http://www.youtube.com/watch?v=C2ilKNxCXMw
Old Apr 5, 2010 | 06:36 PM
shvc1991's Avatar
shvc1991
Perhaps the gas has gone stale. Try adding octane booster and run down that tank and then refill it with fresh gas.
Old Apr 7, 2010 | 01:46 AM
ydjy's Avatar
ydjy
Does the sound change with engine temperature? Which part of the engine is knocking? (top/bottom) Did you check compression? When did you last change oil/check oil level?
There are quite a few moving metal parts in the engine, and almost any of them can be the cause.
Old Apr 7, 2010 | 07:42 AM
MaSfLOw's Avatar
MaSfLOw
wow..hopefully aint a rod..like the above statement where's it coming from top or bottom ?
Old Apr 10, 2010 | 06:39 PM
DarKnight's Avatar
DarKnight
It sounds like it's coming from the top. The sound doesn't change with temperature but it does sound faster when the rpm's go up.
Old Apr 11, 2010 | 10:52 AM
ydjy's Avatar
ydjy
a hole in the exhaust manifold or gasket?
Old Apr 11, 2010 | 11:08 AM
JeffTsai's Avatar
JeffTsai
Sounds like a noisy valvetrain to me. When was the last time you changed the oil?
Old Apr 11, 2010 | 01:40 PM
DarKnight's Avatar
DarKnight
I think it was back in August but that's because I used that Mobil 1 Extended Performance oil that you change once a year. I might go ahead and do an oil change to see if it helps.
Old Apr 11, 2010 | 02:07 PM
iloveGS4xx's Avatar
iloveGS4xx
hey man thats a bs stuff the synthetics oils or the one u used, its not worth of ruining ur engine just use toyota oil, or castrol and change every 3,000 and you'll have no problems with any noises
OIL IS OIL!!!!!!! lol
Old Mar 14, 2013 | 09:52 AM
DarKnight's Avatar
DarKnight
Almost 3 years later that knocking noise finally came to a head. Turned out to be something simpler than I thought, a spark plug . Car is like new .
Old Mar 14, 2013 | 01:44 PM
GS4_Fiend's Avatar
GS4_Fiend
would be nice to see the condition of the spark plug
Cargrub
Jul 8, 2019 11:46 AM
DMPesso
Apr 23, 2015 05:53 AM
TonyCarson
Oct 19, 2014 12:09 PM
2JZ4lyfe
Oct 8, 2014 09:18 PM
GOODFELLA
Aug 20, 2011 12:33 PM
