Radiotor Fan
Old Mar 21, 2010 | 02:31 PM
ivnnln's Avatar
ivnnln
Default Radiotor Fan
Hello guys, I have noticed that my radiator fans did not go off during initial engine start up eventhough the engine still cold. I just noticed this few days. I thought the radiator fans was suppose to start when it reached a certain coolant temperature. Did anyone experience this on GS400's 98? I am thinking either the fan relay switch or the temperature sensor #2 at the bottom of the radiotor tank. The fans's kept running all the time. Any suggestion guys? Appreciated.
Old Apr 25, 2010 | 12:20 PM
stephenis's Avatar
stephenis
Having the exact same problem with my 98GS400.... anyone?
Old Apr 25, 2010 | 02:17 PM
lexo98's Avatar
lexo98
Is your A/C on?
Old Apr 26, 2010 | 01:30 AM
ydjy's Avatar
ydjy
Both radiator fans?
While the fans are running, disconnect the temp sensor and check if the fans run faster. If so, probably the low speed relay. If not, temp sensor, pressure sensor, plugs, wires or both high speed relays. Simple continuity check will tell you the truth.
Old Aug 26, 2010 | 04:29 PM
MkII400's Avatar
MkII400
this is happening to me now, randomly started a few days ago.. please help.
alwabel
Dec 4, 2018 07:07 PM
lapkow
May 5, 2016 09:48 AM
SCB12345
Nov 3, 2015 06:44 AM
ZhiuPei
Sep 1, 2011 04:58 PM
azari
Dec 21, 2003 10:03 AM
