third brake light stays on
Old Feb 14, 2010 | 06:13 AM
samarooai1's Avatar
samarooai1
Default third brake light stays on
i just got my gs and the light on the dash is on for one of the rear bulbs not working .i noticed that all the bulbs was working properly when i checked and the light by the rear winshield wasnt coming off once the lights were on but if i turned the lights off it would come off. what can cause that? and can it cause the vsc and abs and vsc off lights to come on the dash also
Old Feb 14, 2010 | 08:03 AM
ydjy's Avatar
ydjy
hey bro get your punctuation right youll get more response when people know what your sayin the light stayin on is usually the switch near the brake pedal but it cant cause vsc and abs gl
Old Feb 14, 2010 | 08:09 AM
ThomasGS4's Avatar
ThomasGS4
Originally Posted by ydjy
hey bro get your punctuation rightyoull get more response when people know what your sayin the light stayin on is usually the switch near the brake pedal but it cant cause vsc and abs gl
LOL
Fail.
Old Feb 14, 2010 | 08:56 AM
SirBev's Avatar
SirBev
LMAO, I guess you could call this English 101. Okay so what now, the come off and turn off and the....Wait let me look at this again: The brake light that is inside the car isn't staying on when you have not engaged the brakes? Or are you saying that it doesn't come on when you turn on the lights?
Old Feb 14, 2010 | 10:13 AM
samarooai1's Avatar
samarooai1
i am saying that the indicator light on the dash that shows one of the lights in the back is blown shows up but all the tail lights are working fine the only problem is the break light by the windshield stays on without me stepping on the breaks
Old Feb 14, 2010 | 11:56 AM
ydjy's Avatar
ydjy
its either the light failure sensor the light or the wire between them and no this is not related to vss and abs so go scan your error codes
Old Feb 14, 2010 | 01:19 PM
samarooai1's Avatar
samarooai1
the check engine light came on today and it said the brake switch and i think it has to do with the vsc and other lights coming on. cause when the headlights are off none of the vsc and abs and vsc lights come on and when i turn on the headlight all the lights on the dash come on together
Old Feb 14, 2010 | 02:22 PM
SirBev's Avatar
SirBev
I think you should start at brake switch and work you way to issue...
zippinbye
GX - 1st Gen (2003-2009)
Dec 3, 2017 01:35 PM
CalMike
Nov 10, 2014 01:20 PM
WORX661
Jul 9, 2012 07:01 AM
gs4mock2
Feb 28, 2010 03:55 AM
jamie7375
Feb 10, 2008 09:19 AM
