Old Jan 6, 2015, 02:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
Print Wikipost
Steering Wheel annoying Squeaking
Old Feb 8, 2010 | 08:33 PM
KurtK's Avatar
KurtK
Default Steering Wheel annoying Squeaking
Howdy Gang,
I get a faint but annoying squeaking noise when turning the wheel. Seems to be coming from the collumn. Any thoughts on how to silence this?
Old Feb 9, 2010 | 12:18 AM
airestonia's Avatar
airestonia
Is it cold outside where you live?
Mine squeaks as well, but only when it's really cold, like -20 degrees. (Sorry I'm from Europe no Fahrenheit here )
Old Feb 9, 2010 | 07:22 AM
phillygs3's Avatar
phillygs3
I had this problem before, I sprayed some white lithium grease into the column
Old Feb 9, 2010 | 08:49 AM
Infamous 1's Avatar
Infamous 1
Take the plastic off the column, get under there, and grease the gears.
Old Feb 9, 2010 | 10:19 AM
wbmx1981's Avatar
wbmx1981
Could it be that the power steering fluid is low or dirty?
Old Feb 9, 2010 | 10:26 AM
sakataj's Avatar
sakataj
Originally Posted by KurtK
Howdy Gang,
give me a day or so and i will post a video of this exact noise i had, i kept thinking it was coming from my steering wheel so i pulled the steering wheel (ripped the srs plug and had to re-solder it in) and lubed it all up and put it back together and still was squeaking.
FYI its coming from the area on the ground where the steering wheel comes into the car, some white lithuim grease clears it up
again give me a day or so to upload the video (im really behind on my files)
Old Feb 9, 2010 | 09:40 PM
KurtK's Avatar
KurtK
Thanks for the imput guys/gals. To: Airestonia- no I'm in Sunny San Diego Calif,To:- Wbmx- I'm on top of fluids, To:- Infamous- Does plastic just pop off or?? and To:-PhillyGuy- Sprayed anywhere besides the "seam"? Sak - looking forward to your imput too. What a sea of information!
Old Feb 12, 2010 | 07:56 AM
sakataj's Avatar
sakataj
sorry, i havent been home in 4 days. between my busy schedule i been staying at the gf's and havent picked up my laptop....send me a pm please and i will try and remember to get that video for you
Old Feb 17, 2010 | 07:52 PM
sakataj's Avatar
sakataj
ok, i finally remembered. is this what your squeak sounds like? if so, i know what your fix is....
Old Feb 17, 2010 | 08:00 PM
ThomasGS4's Avatar
ThomasGS4
Ha!
Mine does this sometimes. What can I do to fix it, sakataj?
Old Feb 17, 2010 | 11:16 PM
sakataj's Avatar
sakataj
Originally Posted by 1UZ-GS
Ha!
yeah dont do like me....i thought i checked everything and figured it was the steering wheel after i thought i looked. blah....removed steering wheel
if u look closely at pic u will notice i ripped my SRS plug off, had to splice it open and re-solder it (good as new now)
anyways it turned out to be the linkage coming into the car, there is a bushing on the floor. spray or rub some white lithuim grease on it and it will go away. mine hasnt been back since
Old Feb 22, 2010 | 09:13 PM
KurtK's Avatar
KurtK
Bushing on the floor? Maybe a pic or a little more info on where and how to lube this "bushing"? thanks
Old Feb 22, 2010 | 09:55 PM
sakataj's Avatar
sakataj
is this the squeak you getting? click on that image in post # 9 and it will play a video.
no pics...just open door and bend down look where the steering column comes into the car behind the pedals you'll see a bushing there
Old Feb 23, 2010 | 09:22 PM
KurtK's Avatar
KurtK
Got it, Thanks you sadistic bathroom destroyer, but I mean that in a complimentary way
Old Feb 24, 2010 | 02:51 AM
aka paco's Avatar
aka paco
lol just bought a 03 camry SE that has the same steering wheel as my 01 GS and it makes this noise too, i thought it was the steering wheel rubbing the column, but i'll check into what you said Sakataj
