System installed.. quick question.
Old Jan 20, 2010 | 12:27 PM
cloead's Avatar
cloead
Default System installed.. quick question.
I had an old box laying around with two alpine type-r 12's in it, got bored last night and tried putting it in my trunk.
Who would of thunk it was a perfect fit.
Anyways, got everything wired up and installed, but wondering what everybody else was doing for a switched 12v source for amp turn on in the trunk? Right now I have it tied in to my parking lights, but I really don't like driving around with them on all day. Any suggestions were I could pull switched 12v from?
Here is a picture for your time. I know the trunk is dirty I just haven't vacuumed it out yet.
Old Jan 20, 2010 | 12:35 PM
Sash1mi's Avatar
Sash1mi
Check this out!!!!
https://www.clublexus.com/forums/lex...lectronics-12/
They should be able to help.
Old Jan 20, 2010 | 12:53 PM
mtparker18's Avatar
mtparker18
I wouldn't recomment mounting that amp to the box. I blew up a jl 1000/1 doing that. anyway, I'd run the turn on right off the ACC on the back of the stereo.
Old Jan 20, 2010 | 12:59 PM
Mr Jokster's Avatar
Mr Jokster
You can find an open auxiliary slot on your fuse box thats hooked up to your ignition switch. Or just hook it up to your deck (if aftermaket)
Old Jan 20, 2010 | 01:01 PM
cloead's Avatar
cloead
eh its been like that for almost 4 years and hasnt blown up yet. thanks for the advice though. im trying to avoid having to rip apart the interior again, found a line level converter that has remote turn on for the amp built in, might just buy one.
Old Jan 20, 2010 | 01:02 PM
Mr Jokster's Avatar
Mr Jokster
I've heard that myth, but IMO there is usually something else wrong... I've seen some HUGE systems with the amps mounted right over a the port of a cut through in trucks but yea, you would think the vibrations would knock something off, but amp on box is quite a common thing.
Old Jan 20, 2010 | 01:05 PM
Mr Jokster's Avatar
Mr Jokster
Heres a small explanation I gave in a thread of an other member with the same question:
https://www.clublexus.com/forums/gs-...ock-hu-ml.html
he can probably tell you which one he used too.
Old Jan 20, 2010 | 01:16 PM
cloead's Avatar
cloead
Yeah I realized were the fuse box was right after I put everything back together. I read that thread, but I just ordered a line level converter that has a remote amp wire built in, pulls power from the 12v going to the amp, uses a speaker wire to know when the stereo is on, and has a 6v wire to connect the amp. And it's probably built a little better than the box I got at walmart for $15 :rofl:.
http://cgi.ebay.com/PAC-SNI-45T-Trun...item2eaa12b60f
Old Jan 20, 2010 | 02:10 PM
Mr Jokster's Avatar
Mr Jokster
I know technology has come a long way , but I dont like the idea... on the other hand, I know how its working and I wonder if its gonna do the same thing my 'remote turn on' does at home. When it doesnt sense a large enough signal... its gonna shut off. that crap pisses me off!!! LoL again, dont know what will happen. Post up when you get it done and give a review.
Old Jan 21, 2010 | 08:37 PM
mtparker18's Avatar
mtparker18
I know, aha. But I'm just saying from experience.
Old Jan 21, 2010 | 10:01 PM
Mr Jokster's Avatar
Mr Jokster
Ugh, I feel yea... its one of those experiences you wish you were reading about and not posting about electronics suck when you have to replace...
Old Jan 21, 2010 | 10:07 PM
carbongs's Avatar
carbongs
what kind of head unit are you running? it seems that you are running your factory radio. if you are running the factory wire i think it is Radio Amplifier the White/Blue behind the dash.
Old Jan 21, 2010 | 10:12 PM
nguyengs42's Avatar
nguyengs42
That box looks a little small for those 12's but pretty nice tho. You can take out your cd player which is only 4 bolts. Just pull the cigarette lighter out with your hands and pop out the vents with a flat head (cushion it first with cloth or whatever to not hurt your interior. The bolts are 10mm. When you have it out undo the wire snaps and you can splice the remote wire from you amp to the big snap that has a red wire with a + painted on. Then your amp turns on every time your cd player is on.
Old Jan 21, 2010 | 10:14 PM
nguyengs42's Avatar
nguyengs42
Also, if you hooked it into the stock head unit, did you have to hook up the LOC (Line out Converter)?
Kybball#1
Oct 27, 2014 09:41 AM
ExclusivIS
Jul 6, 2006 02:56 PM
kook
Jan 22, 2006 04:11 PM
tommy152
Sep 24, 2003 08:07 PM
Angel
Jul 30, 2003 10:45 PM
