HID Headlight Assembly Removal
Old Apr 25, 2002 | 08:49 AM
whitels's Avatar
whitels
Default HID Headlight Assembly Removal
I got curious last night as to how the front headlight assembly is attached to the body. I removed the three top screws and tried to pry the assembly apart from the body but it won't give. I found one plastic wedge insert in the upper corner part to keep the assembly in place but that's not the one holding up the assembly from getting removed.
Short of opening up the plastic undercover in the front chassis to see from the bottom what's keeping the headlight attached, if any, does anyone know if there's a screw that I missed to loosen or I just need to put more force pulling out the assembly?
Old Apr 25, 2002 | 08:52 AM
wwest's Avatar
wwest
Default MY '00
You must remove the entire front bumper assembly to remove the front headlamp ASSEMBLY.
Old Apr 25, 2002 | 09:37 AM
futuregs's Avatar
futuregs
Default Re: MY '00
Originally posted by wwest
You must remove the entire front bumper assembly to remove the front headlamps.
not true, at the lexus dealer they took out my HID's without removing the front bumper.
Old Apr 25, 2002 | 09:42 AM
Johnny Mo's Avatar
Johnny Mo
GX and 2IS Moderator
Default Search superjoe's posts
guys,
xsuperjoex posted a step by step on how to do it...it was to clear out the turn signal.
Old Apr 25, 2002 | 02:44 PM
whitels's Avatar
whitels
Default Re: Search superjoe's posts
Originally posted by Johnny Mo
guys,
I did research xsuperjoex posting and he also indicated the need to remove the front bumper assembly - with a caution that it is not for the faint of heart. I wonder if I missed the post that you are referring to.
Old Apr 25, 2002 | 02:54 PM
wwest's Avatar
wwest
Default Sorry...
I have the Lexus shop manuals for my GS and I tried desparately to find an alternative to removing the front bumper, no luck.
Old Apr 25, 2002 | 04:21 PM
CSHFLW's Avatar
CSHFLW
The front bumper is easy to remove.....just remove all the screws you see...if it doesn't come off, then you missed one...easy
Old Apr 25, 2002 | 08:14 PM
GS400_PUSHER's Avatar
GS400_PUSHER
Guys keep me post I might have to take mine out..............I am having HID problems
Old Jun 23, 2009 | 08:15 PM
nanotech's Avatar
nanotech
Can anyone Post a link to a complete DIY of the Headlight and assembly removal...
Thanks
Old Jun 23, 2009 | 09:44 PM
Lamchop21's Avatar
Lamchop21
I've taken my headlights out multiple times and you don't have to take your front bumper off. You DO however have to take off certain screws where the front bumper meets the fenders off to loosen create a gap between the two to get some wiggle room and take out the headlight when all the other screws are removed
Old Jun 23, 2009 | 11:58 PM
nanotech's Avatar
nanotech
I have the headlights out, but now i need to know how to take the lens and the housing apart. I know i remember seeing pics on here for a DIY, i cant find it. I need to know what temp to bake at and what all needs to be removed before baking the light.
Old Jun 24, 2009 | 12:56 AM
ItsChris's Avatar
ItsChris
lampchop can you please provide us with which screws need to be removed so this can happen? i need to remove my headlights this weekend thanks
Old Jun 24, 2009 | 07:59 AM
mrkenji's Avatar
mrkenji
i just took out my headlights and i did have to remove the front bumper cover. because there is a bolt for the headlights hidden by the front bumper.
the bumper is fairly easy to remove.. take out the bolts you see and then you need to raise your car up and there is bolts behind the splash guard in the fender that need to be removed and then it should come right off..
then its just one bolt for each headlight that needs to be removed from the headlights to remove them
Old Jun 24, 2009 | 09:29 AM
vwynn's Avatar
vwynn
yea i had trouble removing all the stuff hooked on the headlights.. so i decided to put it all back together n call it a day hah
Old Jun 24, 2009 | 06:33 PM
sakataj's Avatar
sakataj
Thanks
i think jeff has one on his DIY page, check nigels sticky
NinetyFour
Feb 4, 2019 05:02 AM
zzublexus
26
Jan 21, 2019 08:34 AM
Rexor20
Feb 26, 2018 09:51 PM
4renerr
Oct 13, 2017 06:59 AM
vwynn
Nov 10, 2009 10:32 AM
