Question regarding dash light.
Why you sound so mean
Yea I was getting the hyper flash and I got 4 of those load resistors and it solved it!
Here are the ones I purchased:
I believe these are the ones On sale now
Heres vids:
Rear Turn Signals
Front Turn Signals
Here are the ones I purchased:I believe these are the ones On sale now
Heres vids:
Rear Turn Signals
Front Turn Signals
IIRC yes I'm using the exact same bulbs for the rear as the front however depending what year your GS is the size/type of bulb may be different. (meaning the connection from behind) I did have a slight issue when installing cause the bulb was almost the same size as the opening where it was to be installed. and the bulb with the flat connector in back was a bit loose so when I went to install it, it fell into the housing
the load resistors I used are those golden looking ones that i posted on first page, I got them from VLED's I riveted them on to the body of car as to not have them touch anything that could melt or catch fire HOWEVER I highly recommend getting those ceramic ones you can get at kragen. Those gold metal ones got hot pretty fast even when its only on the blinker weird. The ceramic ones stay completely cool, and they are MUCH cheaper than the fancy metal ones. As for install, you can see the install pic I posted and which wires to use (for the rear). each side of the load resistor goes to each wire, one to ground the other to signal wire. The fronts are easy since the wire harness goes straight into the bulb. it was just a matter of using a tap connector as to not cut the factory wires.
ha ha, naw I new you werent being mean
the load resistors I used are those golden looking ones that i posted on first page, I got them from VLED's I riveted them on to the body of car as to not have them touch anything that could melt or catch fire HOWEVER I highly recommend getting those ceramic ones you can get at kragen. Those gold metal ones got hot pretty fast even when its only on the blinker weird. The ceramic ones stay completely cool, and they are MUCH cheaper than the fancy metal ones. As for install, you can see the install pic I posted and which wires to use (for the rear). each side of the load resistor goes to each wire, one to ground the other to signal wire. The fronts are easy since the wire harness goes straight into the bulb. it was just a matter of using a tap connector as to not cut the factory wires.ugh...im so lazy. i dont even wanna do this but seriously these are the ONLY bulbs in my car besides the doors, the cluster and the climate control that ARENT LED. what year is your car joker? if you 2001+ we use the same bulbs (man im lazy i wont even search for what bulbs i use) haha it sucks man been raining here for bout 2 weeks straight now and no im not kidding.
Front turn signals: 1156
(I have an extra set if you want them for a bit less
)Rear Turn Signals: 7443
Those links are for all the types they have, its just a matter of choosing which ones you want, I recommend getting the smaller ones that have like 24 or 27, I dont think the 48's fit, the lens housings are shallow. ALSO, if you have the Headlight Housings that came with your car, then those front ones should be fine, I had forgotten that I had bought a new set of headlight housings for my retro fit and didnt know they changed the bulb in 2003
kind of a weird change in middle of production, anyways thats why I have an extra set cause VLEDS charges like 20% restocking fee
its coo:
will the 48 fit in the front or the rear? i still might get yours jw though
also i have returned stuff to V-LED with NO return charge but i have also spent over 600 with them in last year and half (damn you jackson)
??? who said they changed the bulb in 2003? i just asked what year car u had.
I'd double check though that your front turns are these bulbs:
and these for the rear:
