P0446
Old Sep 15, 2009 | 12:19 PM
arpham's Avatar
arpham
Default P0446
Hey guys! I need help on this one. I searched and I came up with only a few results. I got the P0446 a month ago and it's the Evap system. I checked the gas cap and all that and finally took it to a shop and used the smoke machine to see where was the problem. The mechanic said that the smoke was coming out of near the gas tank underneath the car. I wanted to make sure it's the charcoal canister. hmm any help?
Old Sep 15, 2009 | 02:25 PM
Debonair's Avatar
Debonair
The mechanic was too busy or lazy to bend over and see exactly where it was coming out? Have him hook it back up while on a lift so he/you can see under the car. That's the only way to "make sure."
Old Sep 15, 2009 | 03:55 PM
GS300ToM's Avatar
GS300ToM
yup see exactly where its coming from and report back
Old Sep 15, 2009 | 07:23 PM
BCP43002's Avatar
BCP43002
Check to see if any of the vacuum hoses are cracked or damaged or clogged.
Old Sep 15, 2009 | 08:03 PM
GS4_Fiend's Avatar
GS4_Fiend
Your charcoal canister is above the differential. Do check the evap purge line in the engine compartment where the is a hose with a green cap on it see if it's connected to the intake component side. GL.
Old Sep 15, 2009 | 09:38 PM
4play4dr's Avatar
4play4dr
got this code too..mechanic told me it was my canister..but i think most mechanics will say that cuz they kno its the most expensive part and they'll tell u BS to make some more money..i went to a friends mechanic and he told me it was the canister too..so hopefully he wasnt BSing me..good luck with ur repair(s)
Old Sep 16, 2009 | 09:44 AM
arpham's Avatar
arpham
Thanks for the replies guys. I guess I can call him again so he can put her up on the lift to "make sure", but I jumped to conclusion and bought a charcoal canister from a 2003 for 280 shipped.
& I'll check the evap purge line.... I have the Injen intake for about 9months now and it hasn't given me any problems. hm.
Old Sep 16, 2009 | 06:06 PM
4play4dr's Avatar
4play4dr
where did u get the canister? junk yard?
Old Sep 16, 2009 | 08:39 PM
arpham's Avatar
arpham
Yeah I got it from Gazi on the forum. The stealership wants 850 bucks... crazy
Old Sep 16, 2009 | 08:59 PM
4play4dr's Avatar
4play4dr
dayuuumnnn! does this "Gazi" have more?
Old Sep 16, 2009 | 11:45 PM
GS4_Fiend's Avatar
GS4_Fiend
I don't know where you guys live. But if you live in an area that is sunny, I don't think the canister would be defective that easily. I would high suggest you guys should put it on the lift and check the canister which is on top of the differential first. Check the condition and the vacuum lines first. Hope that helps.
Old Sep 17, 2009 | 12:48 PM
sakataj's Avatar
sakataj
more than likely its a rotted vacuum hose. i think mine had the same code and mine turned out to be a hose
Old Sep 17, 2009 | 06:00 PM
arpham's Avatar
arpham
UGh if it's just the vacuum hose that would suck.
Old Sep 17, 2009 | 06:29 PM
4play4dr's Avatar
4play4dr
^^x2..theres jus too many god damn hoses to check..and most mechanic shops will automatically try to get u to buy the canister..so hard to find a trustworthy mechanic nowadays
Old Sep 18, 2009 | 09:39 AM
arpham's Avatar
arpham
4play4dr - I'm gonna have my car checked again on monday, and if I don't need the canister, and if you happen to need it, I'll sell it to you for what I paid for.
