VSC Problem
Old Aug 26, 2009 | 08:43 AM
milky's Avatar
milky
Default VSC Problem
Hey guys,
I have a problem with my VSC randomly kicking in. Never had this problem until i slammed my car on 20's. I thought it could be because my rear tires have camber wear, and the car was losing traction because of this. So i raised the car and put on my stockers, but VSC is still kicking in randomly. It happens mostly when i hit a small bump or when i turn.
Any ideas?
Thanks in advance!
Old Aug 26, 2009 | 08:50 AM
sonnyg35's Avatar
sonnyg35
i have the same problem sorta but mine just stays on and it wont turn off? and i put the car back to stock too? any input on this issues?
and sorry to thread jack if i am
Old Aug 26, 2009 | 09:48 AM
JiBBeL's Avatar
JiBBeL
Weird. I had the same problem, but mine would kick in when making a turn going fast, not speed bumps. I got new tires and it hasn't happened again in 2 years
Old Aug 26, 2009 | 10:37 AM
Infamous 1's Avatar
Infamous 1
Have you tried resetting the ECU? Unhook one of the battery terminals for five mins then hook it back up. And your ECU should recalibrate.
Old Aug 26, 2009 | 11:15 AM
milky's Avatar
milky
Yea, actually i was gonna do that next, but i wanted to try to figure out what was triggering it in the first place.
Old Aug 26, 2009 | 11:47 AM
Debonair's Avatar
Debonair
Have the ABS/VSC system read for any current or previous diagnostic trouble codes. It should give you an idea about what is going on.
Old Sep 1, 2009 | 01:50 AM
milky's Avatar
milky
So i reset the ECU, and its still doing it. Does the obd II scanner pick up VSC/ABS codes?
Any other ideas?
I forgot to mention that when VSC kicks in, the brakes make this tapping noise.. ugh
Old Sep 1, 2009 | 02:01 AM
Mr Jokster's Avatar
Mr Jokster
hows your brake fluid/brake pads? On my other car I had a similar problem, when I lowered my pulley on the supercharger and did some other mods (gaining a bit more hp/tq) when I stepped on it, the car would launch and the vsc/abs light would go on too. found out that I was low on fluid [brakes worn low]. When I stepped on it, the car would lift and the fluid would move off the sensor and shoot me the light to check my sheeits... I would think car may be out of level in your case.... just a rare thing to throw out there...
Old Sep 1, 2009 | 08:21 PM
milky's Avatar
milky
hmm, my pads are fine, i just had the rear ones changed. Fronts are still good, i'll check the fluid though, maybe that might be the problem.
Old Sep 2, 2009 | 08:04 AM
Debonair's Avatar
Debonair
Any other ideas?
Basic/Generic/Global OBDII scanners will not. Better scan tools with enhanced or factory software will comm with multiple systems like Airbag, ABS-VSC, HVAC, etc.
Get the ABS/VSC system read for any current or previous diagnostic trouble codes.
Old Sep 2, 2009 | 10:10 AM
oooshkin's Avatar
oooshkin
Not sure if its the same issue, But have the Sensors Checked Out or Cleaned.
I've Been Having the same problems On and Off also for the past 2 mths. and Now it Cuts My Throttle Completely along with the engine light coming on.
I've cleaned the Filter / Air system before (inc. MAF Sensor, APS Senor, and the Throttle itself), it was gone for about 3 weeks, and now it's coming Back for good.
Been Reading alot (too much) and found its the Toyota's Drive-by-Wire enclosed System. (All of Toyota Yaris, 4Runners, FJCruiser, IS series owners, etc etc, have been having similar problems.) Either its Skidding Wheels / or Parts Problems.
I finally got it Checked out with a diagnostics and Pin Down a P1120 Code.
But Because of the Drive-by-Wire, it could mean any Sensors that's Not working properly and cause the system to Fail and the VSC light being on and Cutting off throttle.
So Guess tells me if in normal condition without drifting or skidding the wheels, this could mean on of the sensors / Sensor Connectors needs your attention.
Old Sep 3, 2009 | 12:05 PM
milky's Avatar
milky
Thanks for the suggestion, i will get the sensors looked at as well.
Matthias
Apr 24, 2015 10:00 AM
sikkwidit
Apr 28, 2009 11:29 PM
ISzBest
IS - 1st Gen (2001-2005)
Nov 13, 2001 10:09 PM
haveboost
Jun 28, 2001 10:24 AM
