K&N intake wont work, CEL!!! help!!!!
Old Aug 4, 2009 | 12:59 PM
fastryan's Avatar
fastryan
Default K&N intake wont work, CEL!!! help!!!!
Hey everyone, Im new around here and need some help. I have a 2000 gs 400 that I drive pretty hard on a daily basis. I purchased a k&n system for the car, and within a week got code p0171. I replaced the mas, o2's, injectors, fuel filter, all that stuff. I cannot make the code go away unless I put the stock air tract back on, which makes the light go off almost instantly!! any help out there? the car is considerably faster and does get better mileage with the k&n system. ps, its not mental h.p., I'm talking bout' the ability to drift the car through a corner compared to just going fast around it. Anyone else had this happen????
Old Aug 4, 2009 | 01:22 PM
GSteg's Avatar
GSteg
That code normally associates with running too lean. Which is weird because I've had the same intake and I never got any code. In fact this is the first time I've heard of such thing.
In any case, did you make sure the clamps/hose are on tight?
Also disconnect the battery for a little while if you haven't.
Old Aug 4, 2009 | 01:46 PM
kit cat's Avatar
kit cat
I really hope you do this off the streets.
and as GSteg said, check for leaks.
Old Aug 4, 2009 | 03:23 PM
fastryan's Avatar
fastryan
Of course I dont drive like that on public roads, fast some times but not endangering, my buddies and I go to a track a few hours away. Anyhoo, yes I checked all of the clamps, along with any other place that air could leak, still without any luck. Always lean bank 1. I did only replace the front two injectors .
Old Aug 4, 2009 | 05:39 PM
17gs400's Avatar
17gs400
makes sure u dont put the mass airflow in backward
Old Aug 4, 2009 | 06:14 PM
GS300-2002's Avatar
GS300-2002
if your running too lean maybe, probably not, your injectors are just covered in ****. u use injector cleaner very often?
Old Aug 4, 2009 | 07:11 PM
McKrevice's Avatar
McKrevice
lol drift. go watch Fast and the Furious a few more times you riceboi.
Old Aug 5, 2009 | 05:41 AM
Rock-a-Lex's Avatar
Rock-a-Lex
Eventhough unassociated I would check your spark plugs. It could be ironic that as soon as you changed your intake that this code popped due to failing plugs. Once I got this code and I went nuts trying to figure it out. I change all 4 O2 sensors (very important, if you don't know which one is bad change them all as you could have replaced the non-problematic ones). I also found that 2 of my spark plugs were very loose! I tightened them up and re-set the ECU (very important as GSteg mentioned) by disconnecting the negative battery terminal for AT LEAST 30 minutes or more.
GL!
Old Aug 5, 2009 | 07:17 AM
fastryan's Avatar
fastryan
I was using "drift" to explain the power difference, the ability to break the tires loose would have been a better example. I'm not using a 4000 lb car for drifting....jackass. hockey ! Is that even a pro sport anymore????
Old Aug 5, 2009 | 07:19 AM
fastryan's Avatar
fastryan
Ive done all that, new factory spec plugs, resetting the ecu,checked for leaks of all types,changed the battery{hoping it was a voltage issue**
Old Aug 5, 2009 | 09:29 AM
fastryan's Avatar
fastryan
McKrevice, have you ever even had your car sideways, or do ya gotta be careful with it cause your PARENTS are still making payments on it? I guaranty I can whip you around a road course with my girlfriends lil' red vw bug. no drift. Are there sh-- talkers like you on every forum?
Old Aug 5, 2009 | 11:48 AM
slickgt1's Avatar
slickgt1
You know that little thing that connects to the back fo the stock airbox, it has two screws holding it, take a look at the stock box, I have a feeling you didn't take it off. that needs to stay connected to the stock vac line- and a new vac line needs to run to your new intake. Check that. You are deffinatelly sucking unmetered air somewhere.
And yes, there is always someone to say something stupid. Not everyone is like that. Welcome to the forum.
Old Aug 5, 2009 | 11:55 AM
Oleg400's Avatar
Oleg400
Its the MAF sensor clean it, if you still get a CEL after then buy a new one.
Old Aug 5, 2009 | 12:12 PM
slickgt1's Avatar
slickgt1
He said he replaced it.
Old Aug 5, 2009 | 12:29 PM
Oleg400's Avatar
Oleg400
Oh sry didn't see. Just read p 0171 and remember that i replaced mine and it got fixed.
