Sevas s22 offset question
Old Jul 16, 2009 | 05:34 PM
bg_281's Avatar
bg_281
Default Sevas s22 offset question
Well I finally found a good deal for a really good looking set of wheels - Sevas S22... Here's the dilemma... Right now I'm running TSW Kyalami 20x8.5(+40 offset with 245/35/20 and 20x10(+35 offset) with 285/30/20 with no rubbing issues whatsoever... The Sevas wheels I found are 20x8.5 and 20x10 with +25 offset for all four wheels... I want to swap my current tires that are on the TSW wheels over to the Sevas wheels... But I don't know if its going to cause me to have rubbing issues... Does anyone know if I can run those offsets without any issues? ( I already have my rear fenders shaved) Please any info would be helpful... Thanks -Jayson
Old Jul 16, 2009 | 06:00 PM
RidinLow's Avatar
RidinLow
I've got 235/30/20 in the front and 245/35/20's in the rear, front rolled and rear shaved. No rubbing in rear dumped, well the front, that's another story..
Old Jul 16, 2009 | 06:18 PM
GS300ToM's Avatar
GS300ToM
i think your fitment would be nicely flushed without a problem since your rear is shaved
Old Jul 16, 2009 | 08:45 PM
Rides Low's Avatar
Rides Low
Former Sponsor
those are the g35 coupe offsets, they should fit nice, but fender mods will need to be done.
Old Jul 17, 2009 | 01:19 AM
bg_281's Avatar
bg_281
Yea see as long as it doesn't require me to have to go to a body shop and get my fenders pulled and all that kind of expensive stuff then I'll be okay... If i gotta do some more shaving and some minor modification then that's fine with me cuz I can do all that stuff by myself...
Old Jul 17, 2009 | 03:45 AM
BossGS4's Avatar
BossGS4
RidinLow what offsets are you running ? Your tire sizes aren't going to help the original OP unless your wheel widths and offsets matchup to the new set of wheels they are trying to buy.
BG_281 I use this calculator when trying to figure out offsets. http://www.kgm.tiwing.com/calcs/offsetcalc.htm going from +40 to +25 pushes everything out 15mm or a little over a half inch out towards the fender. I run 9.5 +35 with 275s on my rear and have slight rubbing issues on the passenger side. According to the calculator putting a 10 +25 on would push me out 16mm which would require a pull and not just a shave.
You could run stretched or a ton of camber in order to avoid futzing with your existing fenders.
Old Jul 17, 2009 | 02:02 PM
bg_281's Avatar
bg_281
Well that calculator helped me get a really good idea of what im gonna be getting... It told me that the new setup that I want will stick out toward the fender 10mm more than my current setup... which really isn't that much so I think it should work out just fine... So I guess im gonna go ahead and put in that order!!!
Roe
Apr 5, 2016 05:55 PM
tyacrzy
Suspension
Feb 22, 2013 05:11 PM
IcePick06
Wheels, Tires & Brakes Forum
May 27, 2010 01:04 PM
Jaylex
Feb 4, 2009 04:35 PM
Felix gs43
May 3, 2007 06:17 PM
