convert gs 430
Old Jul 3, 2009 | 02:35 PM
kped Gs430's Avatar
kped Gs430
Default convert gs 430
is there anyway to convert my 01 gs 430 from automatic to manual
Old Jul 3, 2009 | 02:38 PM
Baliztik's Avatar
Baliztik
CL Folding 25,000
I'm sure there is. But your car is luxury for a reason. Luxury cars are never manual.
Old Jul 3, 2009 | 03:57 PM
scooter58's Avatar
scooter58
u can do anything u want..
just as long as you have $$$.
there's a price for everything
Old Jul 3, 2009 | 04:35 PM
kped Gs430's Avatar
kped Gs430
are u sure i heard that there was no way i could do this
Old Jul 3, 2009 | 04:55 PM
habeeb89's Avatar
habeeb89
Yes, there is a way. You just have to be willing to shell out the cash and have time on your hands. I remember on a old episodes of the TLC tv show RIDES, they took a 3UZ-FE motor and put it in a IS300 and mated it to a 6 Speed from a Supra.
Old Jul 3, 2009 | 05:12 PM
raytseng's Avatar
raytseng
check out this CL thread as a closer to home example:
https://www.clublexus.com/forums/per...ndustries.html
Old Jul 3, 2009 | 06:21 PM
99Aristo's Avatar
99Aristo
Yay, This guy makes an adapter plate to put a W58 Supra trans into our cars. You use it and the bell housing from your auto trans, a new custom flywheel, and so on. I looke dinto this a while back and thought about it but decided to look for a Sc300 to build for fun. And luxury? lol It's your car, do what you wish with it...some of us find certain joy in not being lazy and shifting gears.
http://www.uza70.com/
This website will give you some insight in what it takes in materials and man hours to do. Good luck man!
Old Jul 3, 2009 | 07:35 PM
kped Gs430's Avatar
kped Gs430
haha thanks looking forward to converting it in the future
Old Jul 4, 2009 | 09:00 AM
sakataj's Avatar
sakataj
yes for some $$$$
BS alot of luxury cars can/are manuals
yup
you can it just takes ALOT of $$
Old Jul 4, 2009 | 09:41 AM
3UZFTE's Avatar
3UZFTE
x2
Like he said, however you only have everything to gain. A 6-Speed (assuming were using the V-16X) V8 would be a beast. Obviously it's not the lightest thing on the road, but no doubt would it crush. But since the 3UZ and 2JZ don't share bellhousings, you need an adapter, in the Rides episode, Rod Millen took the 2J bell housing for the V-16X, cut off the tabs where it bolts into the 2J, and welded the bolt pattern of the 3UZ on the front, where the 2J tabs were which makes it bolt on, clearly not a bolt-on for us. However, if your trying to do it on the cheap, the W58 is nice, cheaper, more available, and a couple companies make bellhousing adapters for 1UZ to W58. There is a down side though, it doesn't handle more then a 350-400 rwhp, according to the IS guys. Start pricing some of this stuff out, and doing some research and I think you'll find your answer.
If it were me, I wouldn't spend that might time and money on something without dropping in the proper components. I would try to source a 6-speed from a Supra, no doubt a 5-speed is cheaper and easier to find, but I mean come on.... You will need the... transmission, flywheel adapter (to convert the GS430 flexplate in a flywheel, a little hard to find), clutch/brake pedals, master/slave cylinders and hydraulic lines, any ecu that the tranny might need, tranny mounts, and I'm guessing you will need a new drive shaft. Did I miss anything?
tcline
Jan 22, 2016 07:09 AM
daj430
Performance
17
Jan 19, 2010 02:37 PM
winwar
GS - 1st Gen (1993-1997)
Jul 1, 2006 05:41 AM
two_xtreme
May 2, 2006 06:25 PM
ViPeRHunTeR
Jan 19, 2003 09:35 PM
