audio help
Old Jun 26, 2009 | 01:57 AM
Takashi02's Avatar
Takashi02
Default audio help
Is it possible to run an aftermarket amps subs and speakers off the stock head unit? i heard the is300s had a problem, where the sounds wouldnt work due to a weird voltage or something like that. is it true with the gs300s? looking to pick up sounds from a friend tomorrow.
Also are there any common problems people go through when installing sounds in the gs? I am really new to sounds to any help would be appreciated
thanks!
Old Jun 26, 2009 | 02:01 AM
Baliztik's Avatar
Baliztik
CL Folding 25,000
You would have to bypass the factory amp. It is better to just get an aftermarket headunit... it creates a lot less headache. Also, make sure you look in the audio section, you'll find your answers there.
Old Jun 26, 2009 | 02:41 AM
SlowNShow's Avatar
SlowNShow
Yes it is possible to run aftermarket amps and subs with factory head unit.
my setup right now is full fosgate rockford subs and amps with my OEM navi. No problem whatsoever...
i wouldnt know how to install it since i got sponsored on audio but i do know that they bypassed the factory amp. the only thing i have to say about the GS with audio is that if you run a box your space is sooooo limited.
Old Jun 26, 2009 | 05:39 AM
Infamous 1's Avatar
Infamous 1
Yes it can be done no problem. There is a DIY on this with pictures and all. Check the "How to" or "DIY" section.
Old Jun 26, 2009 | 09:18 AM
SHiZNiLTi's Avatar
SHiZNiLTi
Sounds to me like you better just bring the equipment your getting to a shop and have them do it.
You need a line out converter, if you look at the bottom of the factory subwoofer you can see (2) wires, you can tap into those using a line out converter, this will give you an RCA connection that sends the input signal to the new amp your getting. Keep in mind it's a 30-80hz signal so trying to use the same RCA's to power lets say 4 channel amp for mids and tweets wont work. You will also need to tap in to a +12v source that turns on when you turn the key, this is called the remote wire and is used to turn the amps on. Then your gonna have to run 4gauge or 1/0gauge power cable from battery under hood through firewall, under trim along doors, poke it through the corner of rear seat into the trunk.
Good luck
If you don't understand the above, bring it to a shop.
Old Jun 26, 2009 | 09:26 AM
AsGs300's Avatar
AsGs300
what he just said!.... this aint no simple civic install!
Old Jun 26, 2009 | 12:47 PM
GS4_Fiend's Avatar
GS4_Fiend
I also got Fosgate P400-4 connected to my factory amp together. Working pretty good.
Old Jun 26, 2009 | 03:50 PM
AC430's Avatar
AC430
Yes it can be done but others are right you loose the factory amp and you might as well go ahead and replace all of the rest of the speakers also for a cleaner sound.
Old Jun 26, 2009 | 11:13 PM
Frankdorn's Avatar
Frankdorn
Do we add the line output converter to the speaker wires right at the sub or before they enter the amp? I've heard both on here...
Old Jun 26, 2009 | 11:37 PM
Takashi02's Avatar
Takashi02
Thanks for all the help sorry pretty new to this forum, i was looking for an audio section but i missed it somehow. i only saw the performance sub-section. thanks ill consider getting an aftermarket head unit. I saw some places that sell the double din kit that you need to fit the double din in, does anyone recommend a particular site or brand of that plastic piece.
Old Jun 26, 2009 | 11:50 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
Yes Carson Toyota has the oem double din piece. It matches and fits perfectly.
Old Jun 27, 2009 | 10:15 AM
tom steele's Avatar
tom steele
your going to spend over a thousand dollars on good sounding tunes then go cheap and buy a line converter. there are many options but i would not do a line converter in my 15 years of car audio all those have done is **** me off with tone of problems engine noise and other problems there are units you can use. rockford fosgate has one so does jl audio and audio control all make great solutions for this problem.
ksan
May 4, 2017 06:08 AM
dewso1
Feb 16, 2012 04:09 AM
ExclusivIS
Jun 10, 2006 05:51 AM
Stealther
Apr 23, 2003 06:10 PM
