wet driver side carpet
Old May 2, 2009 | 04:04 PM
gsCrazy's Avatar
gsCrazy
Default wet driver side carpet - NYC group repair organization for the summer of 09
wet driver side carpet caused by a leak in the ac condensor cover/heater core.
now that the warmer weather has come, i turned on my ac this week and my driver's side carpet is wet again from the leak. has anyone in new york gotten this fixed outside of lexus? lexus is going to cost way too much...
edit: anyone in NYC need to get this done? if someone knows of an independent mechanic we can get it fixed together for cheaper possibly? worst comes to worst we could try to get a deal set up with lexus if a few of us fixes this issue at the same time. let me know.
Old May 3, 2009 | 01:34 AM
BigManne's Avatar
BigManne
got to fix mine this summer too. i really don't want to pay lexus to fix this either.
Old May 3, 2009 | 05:39 PM
gsCrazy's Avatar
gsCrazy
let me know if anyone wants to get their leaking a/c fixed this summer. let's try to get some sort of group deal at either an independent mechanic or even at lexus in the worst case scenario.
Old May 3, 2009 | 07:44 PM
HiHoSilver's Avatar
HiHoSilver
I had the same problem last summer... Took it to Lexus and they told me the same story "ac condensor cover/heater core" at least that's what they thought... Turns out it was the evaporater box that had a leak at the seams (common problem in GS's). Lexus would not replace this part as they will only sell you the entire assembly (go figure). Did not want to spend 2K+ so I had my mechanic repair the evap box and reinstall. So far so good, I used it an additional 3 to 4 months and used it a few times this year and no leaks so far. FYI - Entire dash must be taken apart to access a/c condensor, evap box. Good Luck !!!
Old May 4, 2009 | 08:05 PM
gsCrazy's Avatar
gsCrazy
hey hihosilver,
where in New York is your mechanic located and how much did he charge you?
Old May 5, 2009 | 07:49 AM
sakataj's Avatar
sakataj
lol....u got a believer hiho...
gscrazy don't try "sealing" a ac condenser when and not if, when it leaks again your gonna spend more money/time then you would have done repairing this thing right the first time. plus make sure you dont have any a clogged evaporator line.
if you gonna go through all the time/effort of removing dash just replace this...BUT FIRST MAKE SURE THATS YOUR PROBLEM
here's a couple topics on this
http://us.lexusownersclub.com/forums...howtopic=51893
http://us.lexusownersclub.com/forums...pic=37105&st=0
Old May 5, 2009 | 09:07 AM
Infamous 1's Avatar
Infamous 1
Is there a DIY on how to clean the evaporator hose? I am curious to where it is...
Old May 5, 2009 | 08:31 PM
gsCrazy's Avatar
gsCrazy
that is true sakataj. i'm hoping i could get it diagnosed at hihosilver's mechanic's.
you wouldn't have a good independent lexus mechanic would you>?
Old May 6, 2009 | 11:06 AM
sakataj's Avatar
sakataj
i have argued this with hiho back and forth on those pages i sent you....i personally wouldn't go to his mechanic as i think of this as a bandaid instead of a repair but again this is JUST my opinion. go with whatever is best for you!
me....no im in memphis tn dont know any mechanics there
Old May 7, 2009 | 12:57 AM
BigManne's Avatar
BigManne
have you had this problem sakataj?
Old May 7, 2009 | 08:47 AM
sakataj's Avatar
sakataj
not on my gs (knock on wood)....i would seriously probably blow my car up if this happened to my gs. it happened to my civic hatchback...so depressing to have happen to. BUT wouldn't wanna have this happen and then band aid it with the silicone for it to happen to again a year l8r or whenever
Old May 7, 2009 | 08:34 PM
gsCrazy's Avatar
gsCrazy
i guess i just might have to get this fixed at lexus... that's 3 grand down the drain.... no one else is having this problem in nyc?
Old May 8, 2009 | 03:03 AM
BigManne's Avatar
BigManne
i was going to make sure. i thought you might know someone in memphis that could fix it for the low low.
Old May 8, 2009 | 06:56 AM
HiHoSilver's Avatar
HiHoSilver
Hey GScrazy,
My mechanic was prepared to change the whole assembly, if needed. Turned out I had a pinhole leak at the bottom seam of the evaporator box, mechanic pulled dash apart (very scary to look at), pulled evap box out, filled with water and showed me where the leak was coming from. The evap box comes in 2 halves which are joined together at the seams, unfortunately it is NOT 1 solid peice. If you're evap box has a crack, then you're most likely having to replace the entire assembly or find the evap box at a junkyard. Pinhole leaks at the seams, in my opinion can be easily re-sealed again (all labor no material). It's been a year now and no leaks, so far so good. Mechanic had this same fix on another GS which had the same exact problem (common in GSs) and it's been 3 years now for him and no problems. Do the math, even if this $600 bandaid last three or more years, it's 1/5 the cost to change the entire assembly when you ONLY need that $75 evap box. One would figure that you can buy the box alone (trust me, I tried) but you CANNOT, at least not new.
As far as "sealing a A/C condenser" (sakatj), i would NOT reccommend, I'm referring to the evap box which is made from fiberglass/plastic. My fix only cost me 5 or 600 bucks vs the 3000 Lexus wanted. My mechanic would probably charge someone else more money but he owed me (my brother) a big favor. BTW He's in Brooklyn... Good luck with yours, if you do get a group buy going, I'd love to know how low Lexus would go.
Old May 8, 2009 | 11:56 AM
GS4_Fiend's Avatar
GS4_Fiend
Great INFO HiHoSilver!
