wet driver side carpet
Old May 8, 2009 | 01:59 PM
sakataj's Avatar
sakataj
Originally Posted by BigManne
i was going to make sure. i thought you might know someone in memphis that could fix it for the low low.
oh u didnt ask that. i do know some good mechanics for the low low....what part of ms u in?
Old May 8, 2009 | 03:34 PM
gsCrazy's Avatar
gsCrazy
Originally Posted by HiHoSilver
Hey GScrazy,
My mechanic was prepared to change the whole assembly, if needed. Turned out I had a pinhole leak at the bottom seam of the evaporator box, mechanic pulled dash apart (very scary to look at), pulled evap box out, filled with water and showed me where the leak was coming from. The evap box comes in 2 halves which are joined together at the seams, unfortunately it is NOT 1 solid peice. If you're evap box has a crack, then you're most likely having to replace the entire assembly or find the evap box at a junkyard. Pinhole leaks at the seams, in my opinion can be easily re-sealed again (all labor no material). It's been a year now and no leaks, so far so good. Mechanic had this same fix on another GS which had the same exact problem (common in GSs) and it's been 3 years now for him and no problems. Do the math, even if this $600 bandaid last three or more years, it's 1/5 the cost to change the entire assembly when you ONLY need that $75 evap box. One would figure that you can buy the box alone (trust me, I tried) but you CANNOT, at least not new.
As far as "sealing a A/C condenser" (sakatj), i would NOT reccommend, I'm referring to the evap box which is made from fiberglass/plastic. My fix only cost me 5 or 600 bucks vs the 3000 Lexus wanted. My mechanic would probably charge someone else more money but he owed me (my brother) a big favor. BTW He's in Brooklyn... Good luck with yours, if you do get a group buy going, I'd love to know how low Lexus would go.
Hiho, let me know where the mechanic is. i would like to get this checked out asap.
Old May 9, 2009 | 06:33 PM
BigManne's Avatar
BigManne
Tupelo , Miss
Old May 11, 2009 | 02:05 PM
sakataj's Avatar
sakataj
Tupelo , Miss
not to far...road trip sir
Old May 12, 2009 | 07:17 AM
BigManne's Avatar
BigManne
i think i found someone here in tupelo willing to do it for a decent price.
Old May 12, 2009 | 01:35 PM
sakataj's Avatar
sakataj
cool...keep us posted let us know how it turns out sir
Zilliak
NX - 1st Gen (2015-2021)
May 22, 2019 03:37 PM
Dreamy5522
Oct 6, 2015 05:45 AM
kirby747
Jun 24, 2014 01:28 PM
FastSC300
Apr 14, 2001 11:14 AM
